Scan tool???
Car: 1991 Z28
Engine: 355 TPI
Scan tool???
Ok I need a scan tool that will show me block learn and stuff like that while im driving. Im on my 3rd chip already and im sick of bugging people that have them to use it everytime i get a new chip. I found this at summit will it suit my needs. GM: 1982-1995 vehicles with a 12 pin ALDL connector and OBD-1 computers, diagnostic scanner. its an auto xray scanner. part# AXY-10110 at summit. i don;t care if it doesn't record data or not i can right it down by hand. i havea 1991 Z28 and just need soemthnig to see data while driving. please help!!!!
Car: check
Engine: check
Transmission: check
To be honest, if you have a laptop, even an older inexpensive one, there are free scan/logging tools available.
Both Moates ECM852 and TunerPro are free. And they data log.
OTOH, there are folks that like the Auto X-Ray product.
RBob.
RBob.
Car: 1991 Z28
Engine: 355 TPI
I don't have a laptop and need to get somethnig soon and I live right by summit. I know the lap top would be the way to go but just no time to go searching for one and then getting the cable. but will the auto Xray do what i need it to? the one at summit that is
Car: check
Engine: check
Transmission: check
http://www.autoxray.com/products.aspx?sub=scanners&id=4
RBob.
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
Might work fine to scan, but then what are you going to use to burn new chips? Sounds like the laptop is still the better way to go to me. You can get a cheapie off eBay....
Car: 1991 Z28
Engine: 355 TPI
thanks, I have a place that is buring me chips i just want to check the chips out and give them the ness. info off the scanner that they need when they need to redo them. I already paid the 375 for the chip so I might as well just stick with it till they get it right.
Car: An Ol Buick
Engine: Vsick
Good enough to just keep you happy or what's best for your engine?.
No one can afford to get a chip Correct for 375. They might get close, and some are ridiculously off, yet run OK.
IMO, you'd do better to cut your loses, and get into doing it yourself. Ya, ya, ya, takes work and effort, but all tuning does. There's simply no short cuts, in getting a tune correct.
Car: 1991 Z28
Engine: 355 TPI
I neede something to get by b/c i didn't have the time when my motor got done. I know NO ONE can get a chip correct but they can get it close and it willg et me by for a while. i never understood you ask a question and by the 3rd response its turning ur ? into soemthing nothing what u asked. Someones always gota drop in and say do this do that nothing closely related to my ?. just a lil venting
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
Close by
People here are only trying to help.
Sometime (most of the time
) the best answers come from deviations on the original problem.
And of course many are biased to the DIY of tuning due to the laundry list of problems associated with no doing it yourself.
All in all, the ending point was that for the money already invested, you could be at the point you want to be "in control".
If the time permitted you may have made the steps in that direction.
I'm in Strongsville, PM me if you want to get together and do some work in the meantime.
Who knows, maybe you'll get a cheapie laptop instead of the scanner and then be on a different track.
Jp
) the best answers come from deviations on the original problem. And of course many are biased to the DIY of tuning due to the laundry list of problems associated with no doing it yourself.
Jp
