New Ecm, flashing SES Light????
Car: '02 Z06
i just put in a new ecm and as sonn as i start the car the ses light starts flashing like a strobe light...stock L03 by the way
Whats going on??? The car runs great though so i dont get it.
Car: 1991 Firebird
Engine: 355 TBI
Transmission: WC-T5
I hope you disconnected the battery when you unhooked and rehooked the ecm . . . the power surge could potentially do some damage.
Otherwise I'd have to say its ovbious. Either you have a bad ecm, or it's not the same one you took out.
Car: '02 Z06
Yeah i unplugged and replugged the battery..definantly the new ecm is in..so what is it defective, how could it be if the car is running perfect?????
Car: 1991 Firebird
Engine: 355 TBI
Transmission: WC-T5
If you didn't swap the PROM I'd say that is most definatley the reason for the flasing SES.
Look at your old ecm. Opposite end of the harness, on top of the box there should be a small rectangular panel held down with 2 screws -- 7mm maybe ? Unscrew and pry up the cover gently with a flathead, butterknife or something similar.
Beneath the cover is the PROM carrier. The black plastic thing. CAREFULLY -- pull up on the plastic carrier to dislodge the carrier. The PROM is held by the carrier, and the carrier will only fit one way.
Open the other ECM and remove the PROM -- examine both for reference -- I bet they have different letters or Broadcast Codes. Anywho -- replace the PROM with the stock one. Hook up the ECM, reconnect the battery cable and you should be good to go.
Sorry, I don't know what a PROM tool is. . . Im guessing something like a fuse tool -- but for a PROM.
Car: 1991 Firebird
Engine: 355 TBI
Transmission: WC-T5
no problem - I've had soooo much help from the people on this board i feel compelled to return the favor every chance I get.
eightsixseven
Dec 16, 2024 01:50 PM
