8062
Old Jun 25, 2005 | 06:48 PM
Joelkatdaddy's Avatar
hey, i have a vehicle with a 3/4 350 that i am trying to go multiport on. I have heard from edelbrock that they use the stock ecm and just splice the injector wires so i can run 6 injectors. Would this work, or should i figure a way to swap to another ecm? Thanx
Joel
Old Jun 26, 2005 | 11:24 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Yes, it works. My preference would to to use an ECM that is designed for port injection.
RBob.
Old Jun 26, 2005 | 04:04 PM
Such as what? Ive heard of the 7730 ecm, but i am completely lost on how i would repin that from my 8062 ecm. Any other help would be greatly appreciated. Joel
Old Jun 26, 2005 | 08:27 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
The '730 with the $8D mask is a decent choice. Over on diy-efi.org, gmecm, there are wiring diagrams of the '90-'92 TPI ('730 $8D) system along with the '747 system. The '747 should be very close to the '8062 wiring. May even be the '89-'92 TBI f-body diagrams there ('8746 ECM).
Just need to look at what pin does what and swap them around. Re-pinning really is easy. Just need to put together a pin-to-pin swap chart together first.
Read up on how to program the '730/$8D and go from there. Don't forget some data logging harware.
RBob.
Old Jun 27, 2005 | 12:15 AM
As far as i know, the 7747 and 8062 ecm are very close. I had my truck running on a 7747 for a few days until i realized my AC wouldnt work with the 7747, but it did work with the 8062. Any ideas. Thanx so much for the help.
Joel
Old Jun 27, 2005 | 01:13 AM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
As far as the A/c not working you mean the compressor wouldn't kick on? If so my Jimmy won't run on a 747 because of that. The 747 lacks the control programming to turn the A/c compressor on and off.
Old Jun 27, 2005 | 06:10 PM
ya, but does that mean i cant swap to a 7730 ecm?
Old Jun 28, 2005 | 07:52 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
The '7730 with the $8D code supports a bunch of stuff. The A/C conpressor being one of them. It also has control for two engine cooling fans, CCP, EGR, digital dash, shift light, TCC, oil temperature monitor, . . . Don't HAVE to use all of this, but it is there if you want to.
RBob.
Old Nov 12, 2005 | 01:27 PM
Twilightoptics's Avatar
Car: '87 IROC-Z/'82 RX7
Engine: SBC 355/1.1L Rotary
Transmission: T56/5 Speed
Axle/Gears: 4.33/3.93
So you can swap in a 7730 ecm, which will log faster than the slow baud TBI ecms.... just by re-pinning?
Old Nov 12, 2005 | 03:07 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Only if swapping to a multi-port system at the same time.
RBob.
Old Nov 12, 2005 | 04:23 PM
Gotcha!
odddoylerules
Apr 6, 2015 02:36 PM
Red0ktober
Aug 10, 2010 12:07 AM
34blazer
Jul 3, 2010 04:22 PM
34blazer
Jun 1, 2010 07:12 PM
Twilightoptics
Nov 16, 2005 01:28 AM
