F.A.S.T timing table question
Old Jul 4, 2005 | 01:01 PM
shawnc16's Avatar
Car: 86 IROC, 89 GTA
Engine: 350 blocks, both of em
Transmission: 700r4s
Axle/Gears: 10 bolt and 9 bolt, 3.73, 3.23
aright my car at idle is reading 40 degrees of timing from the light....on the table its reading 34 degrees.. so my question is are the figures supposed to be the same?
Old Jul 5, 2005 | 10:51 AM
89406Iroc's Avatar
Yes they should read the same. To sync the distributor run the vehicle at 2500RPM, check the timing table, if it is in a section that for exmple is 34 deg. check your balancer timing and it should also be 34. If it is not adjust your distributor to correct. (This is if you do not use crank trigger)
At idle the timing will fluctuate too much to verify accurate timing.
Old Jul 5, 2005 | 11:19 AM
shawnc16's Avatar
Ok thanks, thats exactly what i was looking for
Old Jul 5, 2005 | 06:30 PM
BOTTLEDZ28's Avatar
Transmission: A4
not trying to hijack this thread but I also have a FAST question for you. WHile running a realtime datlalog, I notice that while the car is running at idle, the lb/hr. reading flucuates from 12 to 9. Is this right? I am expericancing some serious issues with this engine. It will not rev. it just falls flat on its face. it will idle but the engine shakes a bit. The timing is set to 6 but then reads 10 ATDC when the EST wire is plugged back in.
Old Jul 5, 2005 | 06:32 PM
BOTTLEDZ28's Avatar
Transmission: A4
I also have the last datalog saved if someone can make sense of it or tell me what are normal readings and then maybe I can compare "normal" reading to mine.
here are some of my readings while the car is idling 3 seconds into the run:
RPM 600
MAP 83
BPW(ms) 7.0
coolant 152
MAP(psia)-2.6
air temp 242
actual A/F 15.69
TPS 11
Fuel #s/hr 7.8
battery 13.1
Lambda 1.04
Spark(*BTDC) 21.50
inj. DC% 3.6
Old Jul 5, 2005 | 07:45 PM
maniacc's Avatar
one thing that jump out at me is the air temp....242*F? idling???
Old Jul 5, 2005 | 07:46 PM
BOTTLEDZ28's Avatar
Transmission: A4
ya that has me stumped too. I can figure that one out either.
Old Jul 5, 2005 | 09:51 PM
shawnc16's Avatar
Check the wire diagrams.....you could have possibly crossed the air temp and water temp....
Old Jul 5, 2005 | 09:53 PM
shawnc16's Avatar
Its also running lean
Old Jul 5, 2005 | 10:12 PM
89406Iroc's Avatar
are you running stand-alone or piggyback? I take it you are running piggy back
RPM is too low
IAT is too high, depending on ATS table it is probably leaning it out. For the temp to read that high, your either pulling some real hot air or more likely the IAT sensor is shorted to ground. Disconnect sensor and see if reading changes to -40 or so
BPW looks a little long at idle,but don't mind that yet
Have you set all of your operational parameters?
Is this FAST or XFI?
Old Jul 6, 2005 | 05:44 PM
BOTTLEDZ28's Avatar
Transmission: A4
I am running a stand alone setup. it is a bank to bank FAST setup. not the newer XFI one. I am going to buy a new sensor and see what happens. The one I was using with the TPI setup didnt plug into the FAST harness. The plugs where alomst identical but not the same. I had to take an old sensor out of a spare Y air let setup I had lying around from an older car.
as far as global parameters, I have set them to where they should be. the shop gave me a disk to download and save and all the correct sertting where in there for me. I am going to have it towed to the shop tomorrow
Old Jul 7, 2005 | 09:20 AM
DJ406's Avatar
Maybe I can help a little. I also run a FAST system.
What does your iat sensor read when the engine is stone cold after sitting over night ?( key on but engine not started)
a new sensor cant hurt :')
if you want, send me a copy of your current tune up (GCT) and a data log file. to plumber (at) budweiser dot com
what cam shaft and injectors are you using.
thanks
Doug
Old Jul 11, 2005 | 07:49 PM
89406Iroc's Avatar
BottledZ what did you find out from your vendor?
Old Jul 12, 2005 | 07:07 PM
BOTTLEDZ28's Avatar
Transmission: A4
he has not got in touch with me with any updates on the car. I told him I dont want it back until the car is finsihed being tuned and dynoed.
Old Jul 12, 2005 | 09:39 PM
DJ406's Avatar
never heard from you ,guess you didnt really want help.
Old Jul 12, 2005 | 09:52 PM
89406Iroc's Avatar
Let me know how you like it, the best of luck too ya.
(got to like a guy who's e-mail address is @ budweiser.com )
Azrael91966669
25
Jun 20, 2017 04:04 AM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
