'89 Vats chip in '88 non VATS car
Old 08-12-2005, 01:27 PM
mgomez's Avatar
Car: '88 Trans Am/'96 Trans Am
Engine: L98/LT1
Transmission: 700R-4/T-56
Axle/Gears: 3.42/4.10
I did a little research and from what I've gathered it is possible to place a '89 stock TPI 305 auto trans VATS chip into a '88 TPI 305 Manual non VATS ecm. I'm about to purchase the chip from another member and I just wanted to double check with some of you guys
Old 08-12-2005, 02:07 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
The MEMCAL will work in an '88 ECM. But the engine will only run if that ECM is in an '89 or newer f-body.
RBob.
Old 08-12-2005, 02:15 PM
mgomez's Avatar
Engine: L98/LT1
why is that?
Old 08-12-2005, 02:38 PM
mgomez's Avatar
Engine: L98/LT1
Is there any (easy) way to disable or fool VATS without chip burning?
Spyder_TheGamer
12-25-2015 05:07 PM
Exxon Limited
Camaros Wanted
22
12-21-2015 10:36 PM
NBrehm
08-25-2015 11:49 PM
Exxon Limited
08-09-2015 08:13 PM
djmarch
08-09-2015 05:27 PM
Quick Reply: '89 Vats chip in '88 non VATS car
