727 V8 connectors
Old Jun 3, 2006 | 09:45 PM
Super_GTA's Avatar
Car: 1989 Pontiac Trans Am GTA
Engine: 357 Tuned Port Injection
Transmission: Borg Warner T-5
Axle/Gears: BW 3.45 9-Bolt
727 V8 connectors
I recently bought a 727 ecm off of ebay for my GTA. I wanted to put the ecm under the hood. Unfortunately, I didn't get the connectors for a V8 application. I've searched everywhere, and cannot find the connectors. I did look at the ecm from a 92-93 lt1. It looks identical to the 727. I think the connectors from the lt1 ecm will work for the 727. Now I have to find out where to get those connectors. They have to still make them, because they are used on the painless wiring harness for 92-93 lt1s, correct? Where would I go to find these connectors? Thanks for all your help.
Old Jun 6, 2006 | 03:02 AM
Super_GTA's Avatar
Nobody has any ideas huh? I haven't had any luck with the dealer, parts stores, and Painless Wiring won't help at all. I guess I'll have to abandon the project and go with an under dash ecm.
Old Jun 16, 2006 | 11:49 PM
1tpi's Avatar
Car: 75 Vette
Engine: 406 TPI
Transmission: 700 R-4
Axle/Gears: 373
See DIY sticky first one
Old Jun 17, 2006 | 12:30 AM
Super_GTA's Avatar
I saw that just the other day. I was thinking, what a relief. I took those part numbers and called too many places to count on two hands. Unfortunately, the least amount I can order is 2400 each. No way. Nobody else seems to want to give me the time of day, or if they do, can't find anything. I can keep trying junk yards, or I can just get a 730 and call it a day. I would rather keep the 727, but I don't know if I have much of a choice. Thank you for the help, though.
Old Jun 17, 2006 | 08:30 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
I was going to post the same as 1tpi did. Didn't realize thye would be so hard to obtain in smaller quantities.
As for JY's some of the FWD stuff has '727s under the hood. Front passenger side. Corsica's & Beretta's come to mind.
RBob.
Old Jun 17, 2006 | 11:57 AM
Super_GTA's Avatar
I was wondering about those. Can I still use the plugs from those for my application. I heard you had to have the v8 plugs because of the terminal locations. Thanks for the help guys.
Old Jun 17, 2006 | 02:54 PM
1tpi's Avatar
Car: 75 Vette
Engine: 406 TPI
Axle/Gears: 373
Try Street performance Welcome to Street and Performance
Old Jun 19, 2006 | 10:57 PM
Super_GTA's Avatar
I called Street and Performance. Said he would send me out a kit. I was shocked. After all the places I called, I didn't think I would ever find em. Thank you so much for your help.
5.7RamJet
Aftermarket Vendor Review
May 15, 2007 09:46 AM
nightrider87
Mar 13, 2005 02:13 PM
funstick
Oct 22, 2002 02:50 PM
