1227730 same for 8,6,4 cyls?
Old Aug 3, 2006 | 06:46 PM
ldo_marlin's Avatar
Hello everyone
I am new to FI and have a newbie question.
Looking to multi port FI a 392ci international engine. The 1227730 ECM came in 8,6 and 4 cylinder GMs vehicle. Are they all equivalent and you program the eprom to your motor or are they calibrated differently and I should be looking for an V8 ECM to use.
Old Aug 5, 2006 | 07:35 PM
DENN_SHAH's Avatar
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
the 730 ECM will work fine with any of those engines, the number of cylinders are set in the chip.
you do need a MEMCAL from a 350 for the limp home & knock part of it. you also need a knock sensor for a 350.
the chip will need some tuning for the bigger displacement motor, read the stickies in the DYI PROM board on this site for that & good luck.
gta892000
Aug 11, 2019 11:16 AM
Elephantismo
Feb 13, 2019 12:51 AM
bjpotter
Oct 4, 2015 07:48 PM
kx3g
Sep 28, 2015 08:14 AM
armybyrd
Sep 15, 2015 06:06 PM
