VSS? maf to sd conversion?
Subscribe
Aug 10, 2006 | 12:17 AM
I'm in the middle of the SD conversion from maf, How can I handle this VSS issue? on my '165, the vss input was pin A10, Where can I properly pin this on my '727 ecm so it knows what speed I am traveling? I assume I will have to play in the bin some to get the ppm correct? I also read something about "requires PROM change. Mag. VSS at 0x18 b6 for $8D PROMS", Whatever this means.
Reply 0
Aug 11, 2006 | 01:02 AM
Mike Davis has this well documented.
if 727 and 730 are the same then looks like VSS gets inputed from A10(165) into BC6(730.
look here
http://www.eecis.udel.edu/~davis/z28/ECMs/86to92.txt
Reply 0
Aug 11, 2006 | 02:09 AM
And C6 from the 730 ecm goes into the B16 Port on the '727 ecm. The thing I don't understand is the required prom change it mentions. Is this already done in the super aujp v3? If not, How do I accomplish this? I edit my own proms using Tunerpro.
Reply 0
Aug 11, 2006 | 10:51 PM
Basically what I did was uncheck Switch 18 (VSS M/AT U-TCC I-MAT VSS CCPE) - Bit 6 - VSS. Look under flags and switches.
I have an 86 camaro and run Speed Density. And it works great.
Reply 0
Aug 11, 2006 | 10:59 PM
So with that unchecked, The ecm then Properly reads the signal coming from the speedometer itself?
Reply 0
Aug 11, 2006 | 11:01 PM
yeah it does well it works for me so I thik you should be the same
Reply 0
Aug 11, 2006 | 11:17 PM
Thanks, I saved my bin with it unchecked now, And next time I run out to my car, I will pop the new chip in.
Now if I could fix my ses issue
Reply 0
Aug 11, 2006 | 11:21 PM
whats up with the SES?
Reply 0
Aug 11, 2006 | 11:22 PM
It stays on once I turn on the ignition, And I can't pull any codes. With the A & B terminals grounded, The light still just stays lit.
Reply 0
Aug 12, 2006 | 08:59 AM
If you don't get the SES blink at key-on then the ECM is running in backup mode (limp), not from the PROM.
The SES blink is: at key-on, engine-off the SES will come on, blink off , and come on solid.
That verifes that the ECM is running from the PROM. Need to look into why that isn't happening before continuing. Could be a bent pin, improper burn, PROM in incorrectly,. . .
RBob.
Reply 0
Aug 12, 2006 | 01:07 PM
I pulled the moates adapter and tried just the stock prom and there was no such luck. Still a solid light. Pins are ok as well. When I do a change to the proms I write too, I can tell the difference is happening when I drive. So I don't know. I was thinking a wiring issue, But I've traced all the aldl related wires and they are pinned correctly as far as I can tell.
Reply 0
Subscribe
