computer removal
Old Sep 10, 2006 | 09:04 PM
billybob6110's Avatar
Car: 1984 chevy camaro
Engine: 355
Transmission: turbo 350 2800 stall
Axle/Gears: 3:73 detroit locker posi
computer removal
anybody know how to remove the computer system out of an 84 camaro, 305 carberated?
Old Sep 22, 2006 | 07:09 PM
taonindo's Avatar
Car: 82 firebird
Engine: 406
disconnect them behind where the glove box would be.....youll need a noncomputer controled carb ect...... speedo went elic in 84 i think... and im not sure how that will work or if it will...tao
Old Sep 24, 2006 | 01:00 AM
AtomicTruck's Avatar
Car: Pro Stadium Tough Truck
Engine: Buick V6 272 cu in
Transmission: TH350
Axle/Gears: Broken most of the time
You'll probably have to get a new distributor??. Pull the cap off and check to see if it has any weights/springs under the rotor. If not then you'll need to find a distributor with mechanical/vaccum advance.
There is a tech article on this https://www.thirdgen.org/carbswap Hopefully that helps.
I just went and looked at the article. It is more for an EFI to carb conversion. You already have the intake manifold. But it may help a little.
Old Oct 7, 2006 | 11:49 PM
klause83z28's Avatar
Car: 83 z28
Engine: boat anchor 305 (ex CFI)
Axle/Gears: 3.23 10 bolt
I have a crossfire car that I converted to carb. I pulled the ecu, and kept my computer controlled distrubutor and it runs fine, so you may not have to yank the distributor. It may not work with you though, so who knows.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
Stryker412
Sep 7, 2015 09:11 AM
TheExaminer
Sep 6, 2015 11:40 PM
TBRays98
Sep 6, 2015 05:05 PM
