Trying to pull the ECM...not pulling
Old Feb 26, 2007 | 01:51 PM
92 Camaro's Avatar
Car: 1992 Camaro RS, 66 Mustang, 78 t/a
Engine: 5.0 TBI, 289, 400
Transmission: 700R4, C4, th350
it feels like the ECM is giving me more resistance than just velcro. Its not completely in its case. In fact, I can move it around, and even down some, but it wont fall out. heres a couple pics.
Sorry for the bad pics, best i could do.
Old Mar 4, 2007 | 02:28 AM
89Nighthawk's Avatar
Car: 89 GTA Nighthawk
Engine: 389 CID Vortec TPI
Transmission: TCI 700R4 w/Vigilante
The only connectors are on the bottom that you see so you just have to convince it to come out. You might try disconnecting the terminals plugs first. Good luck with it!
Old Mar 4, 2007 | 07:59 AM
nelapse's Avatar
Car: GTA
Engine: 383 HSR
Transmission: TH-700R4
There are two 7mm bolts that holds it up there. There is a bracket that the ECM mounts to and that has the bolts. Should be perpendicular to the ECM. Remove them and pull hard, this bracket has two plastic dowels so you can only pull down until you clear the dowels then you can wiggle it out.
Old Mar 4, 2007 | 09:50 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
It looks like you just need to pull with more force. The ECM is clear of the retaining ledge. It should pull straight down and out. Maybe it is hung up on something up top.
RBob.
Old Mar 4, 2007 | 01:11 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
my ECM actually had a threaded plastic stud that was under the dash pad holding it in, fortunately the previous owner broke it of...
Old Mar 4, 2007 | 04:36 PM
92 Camaro's Avatar
Problem was found later that day. Part of the bracket was holding it up. Thanks.
wigmobile
Feb 26, 2025 02:56 PM
83 Crossfire TA
Jan 3, 2016 01:26 PM
Amillionoh7
Sep 11, 2015 11:36 AM
sylentnite
Sep 9, 2015 02:55 PM
2012sergen11
Interior Parts Wanted
Sep 7, 2015 11:37 AM
