Tpi Trouble
Old Apr 10, 2007 | 02:45 AM
Allpro's Avatar
Tpi Trouble
I hav an 350 with 92 tpi.
I have done much with this motor, and it would not run great.
Someone who can read the log for me an tell me what to do?
I live in Norway, bad english, but I hope you understand..
It have the com xtream 282 cam, ported, bigger valves, 12-1 comp an so on.
Hope someone can help, In norway no one can...
I cant upload the file here, but give me an E mail adress and I will send it to you.
The Engine starts easy, good idle, and very good throttle response.
But when i am driving I have very good power in 1. gear, and up with full throttle. If I am driving in 3. and want to accelrate, push the throttle slow, it just wont give me power, fells like it dies..
Old Apr 10, 2007 | 03:11 AM
85irocz355tpi's Avatar
Car: 85 IROC-Z
Engine: 355 TPI
Transmission: 700R4w/Shift Kit
Axle/Gears: B/W 9 Bolt-3.45
Re: Tpi Trouble
You need to have a chip programmed for the modifications done to your car. The 92 tpi used a speed density fuel management system and doesn't take well to severe engine mods. Ie cams, heads, and so on. Check online for companies that tune engine computers tell them what you have and they will make a custom chip for your car. That should fix your problems. If you need more info my email is chevroletcamaroirocz@yahoo.com.
Old Apr 10, 2007 | 04:30 AM
Allpro's Avatar
Re: Tpi Trouble
Hello.
I have a new chip, it it made by this guy :www.creativefuelinjection.se
He have made3 different, and he have improved them each time. But the engine doesnt run great.
He says it it a adjustment to timing, or fuel pressure.
I run with 48 psi, and have tryed many different timings.. 0-8 degres--
I have a log, if you ore someone else can look at it for me, i will email it!
Old Apr 10, 2007 | 04:33 AM
Car: 85 IROC-Z
Engine: 355 TPI
Re: Tpi Trouble
you can go ahead and send it and hopefully we can get it sorted out.
Old Apr 10, 2007 | 12:02 PM
Allpro's Avatar
Re: Tpi Trouble
Sendt.. I hope you can help..
Old Apr 11, 2007 | 03:44 AM
Allpro's Avatar
Re: Tpi Trouble
Have you got the file?`
I hope you find sdomething bad there-...
Old Apr 22, 2007 | 01:47 PM
Allpro's Avatar
Re: Tpi Trouble
Nothing?
I have tried out all, soon i take out the engine, and put it at the bottom at the sea.............
Old Apr 22, 2007 | 08:53 PM
Toehead's Avatar
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
Re: Tpi Trouble
hopefully that isnt necessary!
You should also ask your question over at the DUY prom board. Some of those guys know a lot more about the little subtleties of chip programming.
evilstuie
Apr 14, 2016 08:52 PM
Bstrang6
Sep 8, 2015 04:29 PM
theurge
Aug 21, 2015 12:46 PM
Camarothatcould
Aug 20, 2015 08:49 AM
Sanjay
Aug 12, 2015 03:41 PM
