A7, TCC pin has voltage??
Old Aug 23, 2007 | 01:42 PM
Breazlan's Avatar
Car: 88 Firebird
Engine: 302 SBC
Axle/Gears: 4.27 Dana 44
85 TA TPI 870 ecm
Torque converter not locking. Parked with the key on I am getting 8.8 volts on the A7 TCC pin. Is this correct??
Old Aug 24, 2007 | 08:43 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: A7, TCC pin has voltage??
Originally Posted by Breazlan
85 TA TPI 870 ecm
You will get a voltage on the ECM's TCC output pin. It orginates from the ignition switch, goes through the brake pedal switch, to the transmission, through the TCC solenoid, back out of the transmission, and to the ECM.
The ECM grounds that pin to enable the lockup solenoid.
RBob.
Old Aug 24, 2007 | 02:31 PM
Breazlan's Avatar
Car: 88 Firebird
Engine: 302 SBC
Yep, I got that ok. I was getting that voltage from the ECM. Figured it had to be wrong so I took the ecm apart. Fried chip on the board. No codes so it must be isolated to the TCC. My next pondering is why did it fry to begin with? Is something bad with the solenoid? Hate to have it happen right away again.
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
InfernalVortex
Apr 20, 2021 11:31 AM
Elephantismo
Feb 13, 2019 12:51 AM
ramicio
Sep 28, 2015 01:18 PM
327IROC85
Sep 23, 2015 12:11 AM
