3.1 v6 code 43
Old Sep 30, 2007 | 03:31 PM
fbodyalltheway's Avatar
Car: 1992 firebird. 1984 Trans Am
Engine: 3.1L. L76 coming soon
Transmission: 700R4. T56 coming someday
3.1 v6 code 43
got a 92 firebird and keep getting a code 43. the car sometimes idles rough and is slugish and hesitates when i push the gas. and will sometimes die when i come to a stop. bit ago i replaced the ignition moduel and it fixed this problem for about two weeks then it came back. thanks in advance for the help.
Old Oct 1, 2007 | 07:34 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: 3.1 v6 code 43
Code 43 is the ESC system, which is the knock detection and control.
A quick check is to measure the voltage at the knock sensor wire with the key-on, engine-off. With the connector removed from the sensor it should be 5 volts. Then jumper the connector to the sensor and the voltage should be about 2.5 volts. This verifies the wiring to the ECM and that most likely the sensor is OK.
If you don't get 5 volts, then either the wiring or the ECM is bad. If it doesn't change to 2.5 volts when connected to the sensor, then the sensor is bad.
The knock sensor is located on passenger side (US), low on the block, in front of the starter.
After the battery has been disconnected the ECM needs to have an idle learn done. I bring this up because the poor running symptoms can be caused by this. If no idle learn is done it takes about 2 weeks of every day driving for the ECM to learn it in.
RBob.
cking99
Sep 22, 2015 11:33 AM
anesthes
Jun 15, 2005 06:22 PM
TheGreatJ
Oct 26, 2004 07:29 AM
pjd1959
Jan 17, 2004 11:37 PM
90v6rs
Aug 27, 2003 12:03 PM
