first time datta logger
Old Apr 24, 2008 | 09:36 PM
Shadygrady's Avatar
Car: 87 IROC Z
Engine: 5.7 L98 TPI
Transmission: 700r4,2500 stall
Axle/Gears: G80,10 bolt 3.42's
I used winaldl.Just got my usb aldl cable.Ive been having a rich condition but not sure why.This chip was done by tpichips.I plan on getting some tuneing equipment next but in the mean time....When I dattalogged it said DRP occured.Gave me a closed loop flag and a blm enable flag.I had an intermitten or blinking rich flag and an eecc slow O2 rich/lean flag.On the error codes screen it checked the coolant temp low box all the way up to 180*, but I`m showing no ses light.Ijust did this for about 10 minutes at Idle.Cant drive fer now due to I just lost third gear in my trans.But I will datalog some around the neighborhood.Could it be a faulty coolant temp sensor.IAC said 84 to 86.maf was7.6 to 7.9.TPS said 32,2.1,at 63 volts.Gimmie a hand guys.Thanks
Old Apr 25, 2008 | 03:02 AM
Theking's Avatar
Car: 1989 IROC-Z
Transmission: Th700R4
Re: first time datta logger
Try downloading TTS Datamaster and get it scanned with that one.
ITs much better because WinALDL only uses 160 BAUD (good for TBI cars)
Our cars have 8192 BAUD (you could get faster info from it)
And itds much easier to see everything in tts datamaster
Pic from when I logged my car..
As you may see there is much more info to read out.
Its free to use 20 times..
If you want you could upload your logfiles from WinALDL here and i´ll check em up
Old Apr 25, 2008 | 11:08 PM
Shadygrady's Avatar
Car: 87 IROC Z
Engine: 5.7 L98 TPI
Gotta figure out how to save and upload it and I will.
Old Apr 26, 2008 | 03:53 AM
Theking's Avatar
Car: 1989 IROC-Z
In WinALDL you have a button thats named : Datalogger click on it and mark all 4 boxes and click start, then it will save all your data into txt files in the program map, (example : c:\program\winaldl\filenames.. like blm, o2 and ongoing)
You have choosen 1227165 ECM under config right ?
Old Apr 26, 2008 | 01:55 PM
Shadygrady's Avatar
Car: 87 IROC Z
Engine: 5.7 L98 TPI
Yes I chose the 165 ecm,and I did save the O2 and other files that gave me the option to.I`ll see if I can find them.
Old Apr 26, 2008 | 04:29 PM
Shadygrady's Avatar
Car: 87 IROC Z
Engine: 5.7 L98 TPI
I got the tts dattamaster and recorded some but it seems to be telling me about the same stuff.I`m haveing a little trouble finding the propper files to upload.Especialy from tts runs.It keeps saying invalid file
Old Apr 27, 2008 | 05:48 AM
Theking's Avatar
Car: 1989 IROC-Z
TTS datamaster have .uni files
Datamaster reads the info from the ECM much faster (8192baud) and winaldl only 160baud, so its better using datamaster..
Youve saved the datamaster log it should be in the "C:\program\TTS\DataMaster OBD1\DM-32\Testdata" and the name you put on it.
Old Apr 28, 2008 | 08:27 PM
Shadygrady's Avatar
Car: 87 IROC Z
Engine: 5.7 L98 TPI
Cant get it to upload.oh well
Old Apr 28, 2008 | 08:59 PM
yevgenievich's Avatar
Car: numerous
Engine: ls1, others
Transmission: t56, others
Axle/Gears: 3.23 7.6"
try changing extension to .txt to upload
Old Apr 29, 2008 | 02:36 AM
Theking's Avatar
Car: 1989 IROC-Z
yeah .txt or .jpg should work to upload. .uni isnt allowed to upload.
Azrael91966669
25
Jun 20, 2017 04:04 AM
bamaboy0323
Sep 3, 2015 06:07 AM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
Thirim
Aug 9, 2015 06:19 PM
