Performance chips
Old Feb 2, 2009 | 10:21 PM
attica0's Avatar
Car: 83' S-10, 91' Camaro RS
Engine: 305, 305
Transmission: 700R4 in both
Performance chips
im thinking about putting a performance chip in my 91 RS with a 305. if anyone has done this to there car id like to know how it worked out and what kind of chip you'd recommend
Old Feb 3, 2009 | 04:02 AM
89transam*pearl's Avatar
Car: 89 T/A
Engine: LB9
Transmission: W/C T-5
Axle/Gears: 10 bolt posi, 3.73 Richmond Gears
Re: Performance chips
Check out TPICHIPS.Net
Old Feb 3, 2009 | 12:39 PM
Trippeh's Avatar
Car: 91 Camaro RS
Engine: 5.0 TBI
Site doesn't exist?
Old Feb 3, 2009 | 01:57 PM
Ronny's Avatar
tbichips.com or tpichips.com Brian Harris on both
Old Feb 4, 2009 | 12:36 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Advance your timing from stock 0* to around 6-10*. Install a lower temp fan switch in the passenger side head. Install either a 160 or 180* thermostat. Save lots of money and get the same benefit of a "performance chip" mail order or over the internet.
However, only with a custom chip can you get rid of the TBI speed limiter at 110 MPH. (yes you can do the "cut the VSS signal with a switch" mod as described in the tech articles but that's not the "right" way to do it.)
Old Feb 4, 2009 | 12:58 PM
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
Axle/Gears: 10-Bolt/2.73
So on my 700R4 the VSS is disconnected hanging. Found this out but didnt have problems with the trans? It'll be hooked back up when I get back to the maro.
But I plan to go 4* above stock. I have a Stage 2 Stewart Pump, 180 Stat, Royal Purple Coolant Additive and 2300CFM Electric fan with 185on and 170off switch. I think Im good to go.
This should also help me pass emissions as some have even stated and showed (graphs but cant find) more power, more torque (really only thing that matters), and improved gas mileage as well as lowered emissions as this will help burn the fuel as well.
Correct kris or am I trailing off?
Old Feb 4, 2009 | 03:32 PM
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
I'm surprised it doesn't stall (or come close) when getting off the throttle at a stop. Lots of little things depend on that to be connected.
Getting a chip adapter, burner and a laptop to DIY it is the best way in the long run.
Old Feb 4, 2009 | 05:44 PM
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
Well, I have only driven it 3 miles since I bought it in 2006. So I might not have had much experience with the problem.
Thanks for letting me know the symptoms though. A lot of my camaro will be new for 09, and 3 years well worth it.
PurelyPMD
May 5, 2016 04:57 PM
85 Jimmy
Sep 30, 2015 07:56 AM
ramicio
Sep 28, 2015 01:18 PM
Deemax
Sep 12, 2015 06:53 PM
