noob! what is needed?
Old Feb 25, 2009 | 01:22 AM
Nater36's Avatar
Car: 1989 Firebird Formula
Engine: 310 HSR, TFS heads, zz4 cam
Axle/Gears: 9 bolt 3:70
I have searched and cant seem to find wut im looking for .
I am swapping out my 305tpi for a 350 tpi. Ive read up that you need 2 tune for this.
I have the T-5 which may make it more of a tuning issue 2 run correctly.
anyways, my question is.. Wut all do i need to do my own custom tuning? I also plan to put a slightly larger cam with a 108 or so lobe separation so i need 2 be able 2 tune for that as well.
Old Feb 25, 2009 | 07:44 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: noob! what is needed?
If you keep the 305 injectors and 305 PROM with the 350 it will run OK. Although it will run out of fuel on the top end and go lean.
Once you go with the proper (or larger) injectors you will need to set up the tune better.
RBob.
Old Feb 25, 2009 | 10:42 AM
Nater36's Avatar
i have a set of 22/lb oem replacement to cover that. I just need a list of parts for the tuning itself.
not sure wut software/hardware i need for this.
Old Feb 25, 2009 | 10:47 AM
Ronny's Avatar
this may ans a few ?'s.
https://www.thirdgen.org/forums/diy-...uide-book.html
Old Feb 25, 2009 | 10:48 AM
Ronny's Avatar
check out craig moates site. much of what you need is there.
Old Feb 25, 2009 | 06:54 PM
Nater36's Avatar
thank you !
Old Mar 8, 2009 | 07:37 PM
Destructimus's Avatar
Car: 1992 Firebird
Transmission: 700R4 with B&M shift kit
Axle/Gears: 3.23 zexel 4th gen
What kind of investment are we talking about here in order to get started, and how difficult is it to tune an engine that you are not really sure what it has in it?
Old Mar 8, 2009 | 09:40 PM
Nater36's Avatar
i have it all now, www.moates.net had everything i needed
Old Mar 9, 2009 | 10:12 AM
Ronny's Avatar
Build a ALDL cable ($25?)and get the software free (winALDL). Borrow a lappy and see what your sensors are seeing. Read stickies.
Old Mar 9, 2009 | 02:26 PM
Nater36's Avatar
i just spent 55 bux on a zif, 2 chips, and a socket. then i purchased the APU1 package for 320 bux or so.. had everything else neededand more
IROCZ1989
Jan 24, 2016 03:55 PM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
Zachattack0925
Aug 12, 2015 09:52 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
