Auto Prom HELP!
Old Aug 16, 2009 | 03:12 PM
Rally Smith's Avatar
Car: 91 RS
Engine: 305 TBI
Axle/Gears: Factory 2.73 (unfortunately)
Auto Prom HELP!
Alright, I got the Moates.net Auto prom with all the fixings. I have Tuner Pro RT installed on my laptop. I have been searching forums galore and have found no straight answers to any of my questions. I was working on my truck last night for several hours. I got my autoprom hooked up with the cable and chip insert. My laptop sees it. I still do not know how to download the appropriate bin file and the definition file that goes with it. I have tried but with no luck. I have a 1995 GMC K1500 5.7 automatic transmission. I have emailed Craig Moates several times in the last week and no one has gotten back to me. The information that I have found is so limited and assumes that the person reading it knows more than they actually do. I need to know more than I’m reading. I’m positive that more than just myself needs this type of info. I plan on writing up a step by step guide for the beginner once I finally get all of this information and know how to apply it. Is there anyone out there that can help me out please? I am in need of the following.
 How to determine what .bin file you need?
 How to determine what XDF file works with the .bin file?
 How to download the above files into Tunerpro RT?
 Once installed, what is the first step to determine what fields need to be adjusted?
 Where to go into in order to make the changes?
 How are these changes made?
 Etc.. (walk me through getting to making changes and seeing the changes in action.
I was to the point of where I turned my truck to the on position and tried to connect computer to the ALDL cable. Connection failed. I tried adjusting a couple of fields like the “instructions” suggested, but to no avail. Please, please, please, please someone help.
Thanks.
Extremely frustrated newbie tuner
Old Aug 17, 2009 | 03:08 PM
Ronny's Avatar
Re: Auto Prom HELP!
For the appropriate .bin files check Moates file downloads.
same on the bin editor file XDF.
I believe you place those files in "my documents" then TP opens them.
what fields to change? That is up to you. Set the BPC for sure. Modify your VE fueling tables after analysis. Among others. Much info in stickies.
I have never used TP-RT for datalogging. I recall you need the appropriate ADS file. Also at Moates.
What are you trying to accompish with tuning?
Old Aug 17, 2009 | 03:18 PM
Car: 91 RS
Engine: 305 TBI
Re: Auto Prom HELP!
Well most of this is Greek to me. I got the downloads for the .bin & .xdf files now, I think. I am going to plug in tonight and see if it connects to the truck. I guess I will data log first and then see where changes need to be made and wing it. I doubt I'll get that far but if I get...When I get stuck I'll chime back in.
Thanks,
Rick
Old Aug 18, 2009 | 02:35 PM
Car: 91 RS
Engine: 305 TBI
Re: Auto Prom HELP!
Well I got everything plugged in but TunerProRT will not see the ALDL. It sees it in Data Master though. I'm dying here. I'm so damned frustrated! I know it's going to take some time, especially without a user manual that, well, is helpful. Please please don't abandon me. If you have links that will help I'll read them, I've looked all over and my questions don't seem to be getting any answers. I'm at the point where it's plugged in to the truck but I get no love on the ALDL side. Once I do, then where do I go??
Oh, help me naked baby Jesus, help me Tom Cruise!
Old Aug 18, 2009 | 03:10 PM
Ronny's Avatar
Re: Auto Prom HELP!
I have never used TP-RT for datalogging. I will assume the com ports are all aligned.
There are threads here that deal with your connecting issue. I would search posts by Magnus and you may see the procedure outlined.
check this out:http://tunerpro.markmansur.com/FAQALDL.htm
http://tunerpro.markmansur.com/FAQTunerpro.htm#RT1
A similar thread?
https://www.thirdgen.org/forums/diy-...s-winaldl.html
Old Aug 18, 2009 | 03:43 PM
Car: 91 RS
Engine: 305 TBI
Re: Auto Prom HELP!
So am I reading this right from where I got my cable.
MAX232 Circuit
Maxim (and others) make an RS-232 driver chip that provides an assured drive signal voltage and the proper slew rates. This part requires a +5V DC power supply, so the 12V (or self-powered voltage) has to be regulated down to +5V. The 78L05 regulator series is the least expensive and easiest solution for this. (you can find the regulator at almost any parts supplier, Digikey, Mouser, Newark, Radio Shack, etc.) We have not seen an application where the MAX232 will work and the Two-Transistor circuit will not, but if you see one, let us know
Does this mean that I need another regulator in order for the program to see my aldl plugged into the truck? Here's the link to where I got my cable.
http://www.aldlcable.com/sc/pages.asp?pageid=24
Old Aug 18, 2009 | 04:42 PM
Car: 91 RS
Engine: 305 TBI
Re: Auto Prom HELP!
O.k. I think I may have figured out my data logging problem with TP. I just need to jumper these pins on my cable.
http://www.obd2allinone.com/aldl-USBinstructions.pdf
I will try that tonight and see what goes on from there.
I'll be back!
Old Aug 18, 2009 | 08:19 PM
Car: 91 RS
Engine: 305 TBI
Re: Auto Prom HELP!
O.k. I'll be the first to admit I'm a duffus sometimes. I was trying to hook up the ALDL separate from my Auto Prom. So I have my laptop hooked into my Auto Prom via (1) usb cable to APU1 and a cable from the APU1 to the ALDL on the truck. I have tried everything that I can find with suggestions. I still cannot however connect to the aldl. Any idears?
Old Aug 18, 2009 | 10:13 PM
Car: 91 RS
Engine: 305 TBI
Re: Auto Prom HELP!
Progress.
I got the aldl working. I recorded a 20 second run and saved it. Now I don't know how to see the parameters of the playback. How do I see the fruits of my labor?
I made sure the apu1, cpu and truck were hooked up correctly again. I checked the settings in the computer, again. I turned truck on, clicked connect ecm and it didn't find it. I clicked it again and then walla, it connected. Confettie fell from the Heavens, Playboy Bunnies danced around me in string bikinis. It was great for a minute.
Old Aug 19, 2009 | 09:42 AM
Ronny's Avatar
Re: Auto Prom HELP!
I have never used either for datalogging. BUT there are numerous threads about that issue and I suspect temporary in nature. I searched and found quite a few threads about not connecting. I suspect more detailed info is available. Is there a help function in TP-RT out lining the procedure? Maybe send an email to Mark(Magnus).
Old Aug 19, 2009 | 10:51 AM
Car: 91 RS
Engine: 305 TBI
Re: Auto Prom HELP!
I'll try and give Mark a pm and see if he can send me in the right direction.
Thanks,
Old Aug 21, 2009 | 12:30 PM
Car: 91 RS
Engine: 305 TBI
Re: Auto Prom HELP!
O.k. it's been a couple days since I P.M. Mark with no answer.
I think I may have found the proper bin file, xdf file & data stream file last night/this morning. I will try them this weekend.
My laptop says that the ALDL is connected and records but I don't see any data coming in. I don't see any of the information when played back either. Where do I look for the information from a saved session? And/Or why can't I see it? From what I have read, is it the data stream that allows tuner pro rt to see the info coming in from the data log?
Thanks,
Rick
Old Aug 22, 2009 | 05:37 PM
Car: 91 RS
Engine: 305 TBI
Re: Auto Prom HELP!
Damn it! I can't get it any data to flow. I've tried and tried.
I can get the auto prom and the ALDL connections on line. I have been trying a bunch of the 0D mask files in all sorts of combination. I'm frustrated beyond belief. If someone would be so gracious to send me a link for the combination's to use in order to data log my truck I would be so very grateful. I can data log with what I have but I have no information coming out of it. I pull up the Dash view and it doesn't read anything. I'm guessing that is due to the fact the wrong definition file is being used...... I'm about ready to just say screw it and start shooting! Not really but you get the idea. If someone could just throw me a freaking bone here I would be eternally in your debt.
Thanks in advance.....I hope.
Rick
**Can I data log with another program and use it to figure out what areas that I need to adjust? If so what program?
Old Feb 1, 2010 | 10:02 PM
jobambjmb's Avatar
Car: 1987 IROC-Z28
Engine: L98 5.7L
Transmission: 5 speed
Axle/Gears: 3.08 posi.
Re: Auto Prom HELP!
i have the same problems so hang in there well get to the bottom of this, except i can read my data just dont know step by step how to change certin things and what? i need to see this done too or walked though it. ive been trying to figure out how to use this autoprom for a year still havnt burned my first chip yet hopfully soon when i find someone who has.
Old Feb 2, 2010 | 10:46 AM
Ronny's Avatar
Re: Auto Prom HELP!
Is this what you are using?
$31 ECM 16197427
16156930
31.xdf
31.ads
95 C/K Truck/Van 5.7/7.4L
95/96 Hummer H1 (Gas)
Have you seen this? http://tunerpro.markmansur.com/FAQ.htm
Nothing appears in the ALDL Data or ALDL Bits pages. Why not?
You need to have the latest Rich Edit module installed (particularly for Win98/95 users). You can download it here. Unzip this file to your Windows *or* Windows System(32) directory. Altenately, you can also simply unzip it in your TunerPro RT install folder directory.
http://tunerpro.markmansur.com/FAQAutoProm.htm
Old Feb 3, 2010 | 09:43 PM
jobambjmb's Avatar
Car: 1987 IROC-Z28
Engine: L98 5.7L
Re: Auto Prom HELP!
$31 ECM 16197427
16156930
31.xdf
31.ads
hi, im using 1227165 ACXY ECM, 6e.xdf, datastream deffinition file and it's in an 87 iroc-z, i swapped out the 305 for a 350 and built up the rest of the motor too. put in a closer chip from hypertech until i could find somthing better, the dyno guy said i needed a bigger fuel pump and they knew someone who could burn me one closer to my specs but then i found the autoprom and kinda fell in love with the whole idea of it because ive learn so much allready with it and want to be able to see what its doing on and off the track. and burn my own chip, so i got the big holly pump and searched for all info and forums at moates and tunerpro RT. also moates youtube which was helpful but didnt see anybody on there change some tables step by step, i guess you just change certin parts of the table like that guy they show doing it on a ford mustang for like the rpm with a simular tuner even that isn't very up close, so he clicked certin stuff on a piticular table then hit upload to autoprom, verify sucsess and it changes then you can change back, then the same for other tables except stuff like flags and constants, any way just looking for some one who has actully used this them self and maybe some more hands on video thanks for the reply.
Old Feb 3, 2010 | 09:53 PM
Duts87ss's Avatar
Car: 1987 Monte Carlo SS
Engine: HSR 383 AFR180/268XFI EBL
Transmission: 200-4R, Edge 2800 L/U
Axle/Gears: 7.5/3.73/PowerTrax No-Slip
Re: Auto Prom HELP!
Using MAX32, you need the outside switch on the AutoPROM switched towards the outside. With it switched to the inside you should change the MAX32 setting to AutoPROM.
You'll also need the correct .adx file.
Old Feb 3, 2010 | 09:56 PM
jobambjmb's Avatar
Car: 1987 IROC-Z28
Engine: L98 5.7L
Re: Auto Prom HELP!
whats BPC and VE fuel tables? thats the type of stuff i want to know, what other tables? hey rally smith hope you got some where when i had that same problem just the switch wasnt in the right possition even though i thought it was good luck!
Old Feb 3, 2010 | 10:05 PM
jobambjmb's Avatar
Car: 1987 IROC-Z28
Engine: L98 5.7L
Re: Auto Prom HELP!
rally smith try playing with the stuff at the header on tunerpro RT youll find it.
Old Feb 4, 2010 | 01:56 PM
Ronny's Avatar
Re: Auto Prom HELP!
I saw the 1995 GMC and assumed that was the platform. BPC = base pulse constant. It is your CID/injector size-# of injectors/fuel pressure calculated to form a constant. Mine happens to be 92 but yours will differ. VE is volumetric efficency. That table has fueling values for RPM vs MAP. Not sure is 6e.xdf has VE tables? Are you MAF or SD? SD has VE tables. I recall MAF does not. I am SD.
Linson
Oct 24, 2025 02:00 PM
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
sp8ty
South East Region
Sep 24, 2018 03:55 PM
Linson
Oct 1, 2015 09:50 PM
dusterbd
Sep 29, 2015 08:40 AM
