Code 45 rich running and a bunch more... whats wrong?
Old Jan 19, 2010 | 12:03 AM
92birdy's Avatar
Car: 1992 Firebird
Engine: 3.1
Hi again, this car never fails to let me down HAHAHAHA. ok heres a list of whats wrong 3.1 liter motor
1 engine misses at idle in park on occaision
2 a few months ago i had where when the car (auto) shifted up 1-2 it bogged out almost to a stall and shifted
3 was driving about 50 mph and it was locked out but a miss started and it really puttered down the road
4 always has run rich for me changed o2 and did an exhaust system and its still shooting powder off the tail pipes but tonight gave me a code 45 at idle in park
5 at idle in drive it almost stalls in drive (to the point that i quickly throw it in neutral and rev up to keep it alive) it has stalled a few times
6 now that its colder it does hesitate a lot when running the first few minutes
im sure theres more that im forgetting but any ideas?
Old Jan 21, 2010 | 11:37 AM
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
Re: Code 45 rich running and a bunch more... whats wrong?
Sounds like you have a misfire issue caused by the ignition system/fouled pugs/bad wires.
The misfire will indicate excess air in the exhaust from the unburnt charge resulting in a lean indication to the ECM. The ECM will attempt to add fuel and compound the problem.
Check/clean the plugs, confirm plugs are correct and gaps are right, check wires are good (or just replace them)
Check any other ignition parts for possible problems and then see if things improve.
Putting a scanner on it would confirm the o2 readings indicate lean.
Old Jan 21, 2010 | 02:30 PM
92birdy's Avatar
Car: 1992 Firebird
Engine: 3.1
actually i just redid all of my plugs and wires cap and rotor less than a thousand miles ago so i didnt see how that would effect it... i already had a computer go bad so i didnt know if there was some other random computer or chip that could be doing this as well hahah
Old Jan 21, 2010 | 02:45 PM
wesley_pontiac's Avatar
Car: 86 Pontiac Firebird
Engine: 2.8 liter V6
Axle/Gears: 10 Bolt 2:73
have you messed with your ignition module any? cuz there is that possibility that that it mite be goin bad.
Old Jan 21, 2010 | 04:14 PM
92birdy's Avatar
Car: 1992 Firebird
Engine: 3.1
actually no, ive never messed around with that... is that a common problem?
Old Jan 21, 2010 | 08:23 PM
ehhhh,not rly but its just that u kno 1 item is gona stop working properly eventualy. haha.
Old Jan 24, 2010 | 02:52 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Yes, it is. I'm on my third, and I'm sure it was replaced before I bought the car, being that the one that was on it was a Wells unit (not factory). However, I seriously doubt that is your problem. Generally when the module goes, the engine either doesn't start or it will jerk really bad on acceleration, with a jumping tach needle. Some guys I know even carry spares in their vehicle for when they go.
How old is your ignition coil? Have you tested the signal coming out of your IAT, MAP, and CTS? Any one of those 4 things can lead to this problem. Oh, and I almost forgot... Do you have any exhaust leaks?
Azrael91966669
25
Jun 20, 2017 04:04 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
squiggy2
Aug 9, 2015 09:30 PM
