89 IROC no injector pulse?
Old Mar 28, 2010 | 09:32 PM
Brett1957's Avatar
Car: 1989 IROC
Engine: 5.7 TPI
Transmission: 700R4 w/shift kit
o.k. I have a 5.7 350 w/aftermarket cam, pistons, bored.30 over. It has been timed and the VATS bypassed correctly. All the systems are working correctly except injectors/ no pulse? here are the things i have checked
1. 12v to both sides of the injectors
2. 12v drops to 6v when engine turns over
3. ignition module was checked by parts store/ brand new dizzy
4. TPS shows 4v+ almost 5
5. ECM appears to be functioning properly
6. Fuel pump is primed and pressurized
7. Engine ground is good
8. Spark plugs have fire
If I am missing something please advise...
Old Mar 28, 2010 | 11:42 PM
ATX-Iroc's Avatar
Car: 87 Iroc-Z
Engine: 305 tpi
Transmission: 700-r4
Re: 89 IROC no injector pulse?
I recently had a problem with the ecm leaving the injectors open and it turned out to be the ecm itself. I would try another ecm.
Old Mar 28, 2010 | 11:53 PM
KNBlazer's Avatar
Car: Trailblazer EXT 4.2 (Firebird Form)
Engine: 5.1 4bbl
Transmission: 700R4 Mega Raptor Level 4
either the ECM or ignition module... just because it tested good doesn't mean it's good... ..
Old Mar 29, 2010 | 08:20 AM
884+3's Avatar
Car: 88 irocz
Engine: b2l 350
Transmission: corvette 4+3
If your TPS is showing 4v with the throttle closed there is something wrong with it. The ECM goes into "clear flood mode" if it sees that much voltage from the TPS while cranking, shutting off the injectors. It should show .54v with the throttle closed. Replace or free up the TPS and you should be ok.
Old Mar 29, 2010 | 10:28 AM
stampede52's Avatar
Old Apr 3, 2010 | 12:09 PM
Brett1957's Avatar
Car: 1989 IROC
Engine: 5.7 TPI
Ok here is a stupid question, would a custom programed prom cause this problem? the car had an an after market msd box on it...i took it off when i bought it so i could return it back to factory to trouble shoot other problems w/the car. but then i noticed that the prom had an aftermarket sticker over the glass part on the prom...two race flags with performance something or another on it... so could this be the problem...do i need to wire it back up?
Old Apr 3, 2010 | 11:12 PM
ATX-Iroc's Avatar
Car: 87 Iroc-Z
Engine: 305 tpi
Have you fixed the tps yet if not do that immediately and then test the pickup coil as it has alot to do with injectors firing. Are you one hundred percent sure the injectors are not firing and how are you testing for this? Try disconnecting your ecm find a pinout diagram and see if you can manually fire the injectors to rule out broken wires.
Old Apr 3, 2010 | 11:17 PM
juanillox8's Avatar
Car: TOO MANY
Engine: 350 TPI / 350 TBI/6.0L VORTEC
Transmission: T5/AUTO/AUTO
wondering what did u use to bypass the vats???????
is ur check engine light on??
Old Apr 4, 2010 | 08:08 AM
884+3's Avatar
Car: 88 irocz
Engine: b2l 350
Where are you seeing this voltage drop? If it's at the inj. harness then it sounds like the ECM is doing it's thing and controlling the inj. The next logical step would be to check the fuel pressure at the rail. These TPI engines require at least 35 psi to force the fuel through the inj. Also check the voltage going back to the pump.
justin57
Aug 20, 2015 07:05 PM
tmellott89
Aug 16, 2015 02:58 PM
kyleb24
Aug 15, 2015 08:24 AM
mustangman65_79
Aug 11, 2015 03:17 PM
