Lean running
Old Jun 22, 2010 | 08:02 PM
campbellerman's Avatar
Car: 1990 Trans Am
Engine: 305 TPI L98 cam
Axle/Gears: 3.42 eaton
Lean running
Hey guys i just bought an aldl cable and i am wanting to start tuning my own car. I did some datalogging a few minutes ago and i saw that my BLM is 160 Which indicates a ?lean? mixture. is this a normal value with all this stuff removed?
car was idleing in closed loop at operating temperature
all data values are in spec
minimum air and tps set
and just on a side note i dont have smog at all its been completely removed but not programmed out yet
and egr valve is on the car but the solenoid and all the vacuum lines have been removed and the ports plugged
Old Jun 23, 2010 | 02:38 AM
xch3no2's Avatar
Car: 89 K3500 Fleetside
Engine: RAT *tbi* EBL
Transmission: TH400
Axle/Gears: 3.73-Dana 60
Re: Lean running
Ya 160 is way lean. Check for any vacuum leaks, low fuel pressure.
128 is the BLM goal. You can boost fuel pressure to drive BLM's down until you get your tuning hardware.
Old Jun 23, 2010 | 09:33 AM
Car: 1990 Trans Am
Re: Lean running
i know my egr valve is bad but could just not having it hooked up cause it to run this lean? i am going to pick up a new valve this weekend
Old Jun 23, 2010 | 02:43 PM
xch3no2's Avatar
Transmission: TH400
Re: Lean running
An EGR stuck open will lean the mixture.
Just plugging it tends to fattens the mix slightly, during times when EGR operation is commanded.
Old Jun 24, 2010 | 12:10 AM
Car: 1990 Trans Am
Re: Lean running
ok thanks. i am going to get a valve this weekend and hook everything back up theres no reason why this wouldnt help the lean condition right?
Old Jun 25, 2010 | 12:04 PM
xch3no2's Avatar
Transmission: TH400
Re: Lean running
If your EGR IS defective your engine will love you for replacing it, it's suffering.
Make sure your exhaust is fully sealed, any leaks can throw O2 readings off.
The EGR would have to be stuck open for the lean symptom, this a less common failure but happens.
Without knowing this is the case, I cannot confirm your last statement.
Old Jun 25, 2010 | 12:51 PM
Car: 1990 Trans Am
Re: Lean running
there is no exhaust leaks and the egr ports are clean. i replaced the valve today and it seems to run better. it is still running 160 block learn though: i have 42 psi at the rail and 38 while running air pump and smog has been removed
Old Jun 25, 2010 | 03:23 PM
xch3no2's Avatar
Transmission: TH400
Re: Lean running
It's time to get after the fuel pressure. Use BLM's as a guide.
4oohp wont be very happy w/stock bins.
What are your intake manifolds like? Fuel pump?
The members here have done endless work & posted mind boggling wealth of info.
Your in the right place to learn.
In working with tuning your computer it's best if I hand off to these guys.
As I still have sooo much to learn.
The Rabbit hole is quite deep.
Follow the Rabbit..
Old Jun 25, 2010 | 04:07 PM
Car: 1990 Trans Am
Re: Lean running
this is my 1990 305tpi trans am that i am having the problem with
Old Jun 25, 2010 | 04:38 PM
xch3no2's Avatar
Transmission: TH400
Re: Lean running
Ahh I see now.
Maybe * or / between equipment descriptions will also help, I don't always read so good. lol
Add fuel pressure
Old Jun 26, 2010 | 12:46 AM
Car: 1990 Trans Am
Re: Lean running
lol ok i will remember that thanks for all your help now to bump the fuel pressure i will need an adjustable regulator how much do these usually run and what is a good brand that i can look into?
Old Jun 26, 2010 | 09:45 PM
xch3no2's Avatar
Transmission: TH400
Re: Lean running
I have used the Jet, it works good, its blue.
Vacuum reference models are useful for some builds, your stocker won't need that.
Other's might have another favorite worth looking at.
You will need to use your diaphragm, or get a new one if yours is hammered.
Old Jun 26, 2010 | 11:39 PM
Car: 1990 Trans Am
Re: Lean running
and the new one just goes in place of the stock regulator cover?
Old Oct 13, 2010 | 04:48 PM
Car: 1990 Trans Am
Re: Lean running
hey i installed an adjustibl regulator today and fuel pressure isnt affecting BLM at all only the INT. im stumped WHY is this thing running lean?? please help
Old Oct 13, 2010 | 05:58 PM
xch3no2's Avatar
Transmission: TH400
Re: Lean running
You did not mention what pressure you set, very important.
Be patient while it tries to do it's thing, I got 'fused again w/your vehicle description, can you rearrange/split that up somehow?
I wasted much thought & typing on a 400hp tpi. My bad.
It does take some driving, & cold start, run to temp cycles for the computer to fully adjust within it's capability. To reset the computer getting rid of stored settings disconnect battery for 2 min.
Some tuning gear is next in order, to tune your computer see moates.net
there you will find all the gear you need.
To upgrade your computer to what I'm using see dynamicefi.com
Naturally I recommend the latter.
WARNING!
Our moderator may move this thread to a more appropriate section.
Old Oct 13, 2010 | 07:03 PM
Car: 1990 Trans Am
Re: Lean running
I reset the ecm im going to drive it for a few days and see what happens. car seems to run fine
Old Oct 13, 2010 | 07:09 PM
xch3no2's Avatar
Transmission: TH400
Re: Lean running
Way cool
& the reason I gave warning is,
This section is for rather advanced discussion/topics, I mostly just read to learn more in here.
Old Oct 14, 2010 | 10:25 AM
Ronny's Avatar
Re: Lean running
Does engine break up or pop pop out exhaust when you accellerate hard?
eightsixseven
Dec 16, 2024 01:50 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Street Lethal
Aug 14, 2015 08:25 PM
apie2546
Aug 10, 2015 05:43 PM
IROCThe5.7L
Aug 10, 2015 11:24 AM
