I am new to tuning, help me out on learning!
Old Jan 2, 2011 | 12:46 AM
david068513's Avatar
Car: 1992 z28/1992 RS heritage edition
Engine: 350 tpi, 305 tbi
Transmission: 700R4,T5
Axle/Gears: G92
Ok first off my car is a 1992 Z28 L98 G92 car. ported plenum, SLP ported plenum, vortec heads, vortec intake, 52 mm TB, etc. It's a mild bolt on car. I do plan to add AFR 190 heads, a stall, and a decent cam to match the heads etc. I also want to add a 150 shot. This is the issue I am running into. I want to start learning and tuning the car. I want to be able to load multiple tunes. One for the NA setup and one for the nitrous setup. I don't want to have to redo the tune every time I want to spray it. So what I am wanting to know is what setup would be best for me? what will I need? where do I find it? how do I learn? websites and links to how to use it, etc.
Old Jan 2, 2011 | 06:39 PM
xch3no2's Avatar
Car: 89 K3500 Fleetside
Engine: RAT *tbi* EBL
Transmission: TH400
Axle/Gears: 3.73-Dana 60
Re: I am new to tuning, help me out on learning!
I recommend you start with a through reading of RBob's website,
http://www.dynamicefi.com/
Old Jan 3, 2011 | 12:12 AM
Axle/Gears: G92
Thanks for the link. I am gonna check it out and do some reading, anyone else got any links or info I should know?
Old Jan 3, 2011 | 08:49 AM
black85vette's Avatar
Car: 1985 Vette
How is your basic understanding of how the ECU and sensors function?
I have found this book extremely useful:
http://www.amazon.com/Corvette-Injec...4065132&sr=1-1
While it was written for the Corvette, actually it is a great reference to the GM fuel injection systems. The author was going to write one for other cars but unfortunately died just after this book published.
Old Jan 3, 2011 | 01:47 PM
Ronny's Avatar
check craigmoates site for a .bin switcher as well.
Old Jan 5, 2011 | 11:55 PM
Axle/Gears: G92
what's a .bin switcher? to switch between each tune?
Old Jan 6, 2011 | 10:08 AM
Ronny's Avatar
yes. I had one on my Prominator and also have one on my EBL. Prominator was on dash board. EBL requires I have laptop on and EBL program running during change of .bin.
Old Jan 6, 2011 | 09:18 PM
xch3no2's Avatar
Transmission: TH400
No laptop required,
http://www.dynamicefi.com/EBL_FlashSwitcher.php
Old Jan 7, 2011 | 09:22 AM
Ronny's Avatar
WOW I need to upgrade EBL ! Unfortunately financially embarrassed...
Old Jan 7, 2011 | 12:56 PM
EagleMark's Avatar
I'm surprised no one mentioned to read all the stickies in this forum and the chip forum. In those stickies are also dozens of links to read.
As far as the hardware to switch .bin files Moates has all you need!
Rocket-Doc
Nov 14, 2015 02:08 PM
mfp189
Sep 27, 2015 09:25 AM
