No longer here
Car: 1991 z28
Engine: 305 tpi
Transmission: 700r Automatic
Re: ECM's For Sale
will any of those work properly in a 1991 camaro z28 305 tpi with map sensor and electronic speed vss automatic 700r4?
Car: 1985 IROC-Z28
Engine: LB9
Re: ECM's For Sale
a 1227730 will work in a LOT of applications.
any of the 90-92 F-bodies with the exception of the TBI motors.
the AUPC MEMCAL is meant for a 1990 L-body(corsica/beretta) with a 3 speed auto though, that would need to be swapped out for a correct MEMCAL.
Car: 91 firebird Formula 350
Transmission: N/A, working on a t5 swap
Axle/Gears: 3.73 posi
Re: ECM's For Sale
I'm trying to decide if I should swap a 350 into my 305 tbi on my 91 firebird, but I'm not sure if I need to swap the ecm or not. I think I would have to, but I'm having a hard time finding and/or understanding information for this. any advice? And would any of these even work with what I'm trying to do? (305-350 tbi)
Re: ECM's For Sale
My ECM number is 01228746.
and my PROM says: ANTT 8026
I dont see anything resembling the picture of the memcal thats in the sticky at the top... only the prom, a barcode/serial number, and a tiny chip with no numbers or ID on it.
Any help would be much appreciated. I want to do this engine swap, but this computer stuff is way over my head, and I havent been finding a whole lot about the specifics for the ECM/PROM swap that I may or may not need?
I hope its just the prom that needs switching. That would make this a lot easier.
I hope its just the prom that needs switching. That would make this a lot easier. Trending Topics
Car: 89 K3500 Fleetside
Engine: RAT *tbi* EBL
Transmission: TH400
Axle/Gears: 3.73-Dana 60
Re: ECM's For Sale
This isn't the place to sell your junk...
Thank You
Thank You
Re: No longer here
Pac J
May 17, 2020 10:44 AM
