Where is 92 computer and what pin to read codes?
Car: 1992 z28/1992 RS heritage edition
Engine: 350 tpi, 305 tbi
Transmission: 700R4,T5
Axle/Gears: G92
How do you access a 92 computer and what ports do I push to see codes? Just use a paper clip?
Car: 1985 camaro Z28
Engine: 305 5.0 V8 carburated
Re: Where is 92 computer and what pin to read codes?
IT's the uppermost right two holes. A and B to check for codes. The computer itself is under the passenger side of the dash.
Axle/Gears: G92
Just pull that kick panel off and I can do it or so I need to move it out someway from however it is mounted in there
Car: check
Engine: check
Transmission: check
RBob.
Axle/Gears: G92
Ok, what should I use to push in the connectors? A paper clip? Or what?
Car: check
Engine: check
Transmission: check
The ALDL connector is next to the fuse block. Drivers side, above your left foot. Can use a paper clip there to have the ECM flash the codes. A paper clip works.
RBob.
Axle/Gears: G92
I'm not sure, but there may be some confusion here. If the access to the computer is to flash codes, there is no need to pull it out of it's mounting.
RBob.
RBob.
Car: check
Engine: check
Transmission: check
Axle/Gears: G92
Axle/Gears: G92
Codes 32-EGR failure, 42-EST system failure, 43-ESC Knock sensor failure.
could the timing being off cause that code? also what do I need to do about the egr? should I fix it? If I delete it will it throw the code? I need to fix this by fri cause I am driving it a hour away and don't want any issues.
eightsixseven
Dec 16, 2024 01:50 PM
