Self-tuning EFI options/discussion
Old Jun 3, 2011 | 05:02 PM
88TPI406GTA's Avatar
Car: 2009 Pontiac G8 GXP
Engine: LS3
Transmission: 6L80E
I don't want to hijack the EZ-EFI install threads on this...so hear is a new thread.
I have done some research on the EZ-EFI, Holley Avenger, Professional Products EFI (Powerjection III), etc. What system offers the best bang for the buck (under $2K) that has best options, etc. I am doing the research to upgrade from TPI, so I am not starting from scratch.
If I understand this properly:
EZ-EFI: Self-tuning, but limited in other control options, including no spark control
Cost: $895 for ECU and harness (retrofit to TPI)
Accel: No-self tuning, but has optional control of fans, spark, knock sensor, etc.
Cost: $1,800?
Powerjection 3: Self-tuning, good replacement for existing carb
Cost: $1700 for all, including TB
Thanks for the info...
Old Jun 3, 2011 | 08:59 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Self-tuning EFI options/discussion
Cost: $1,800?
I don't usually get involved with these threads, but, EBL P4 Flash, for MPFI systems. All emissions equipment is available, 1, 2, or 3 bar MAP (2/3-bar for boost compensation), dual fans, N2O wet control, VE tables to 8,000 RPM, SA tables to 6400 RPM, high idle for those with on-board air or welding, A/C and fan cut off in PE mode. The list goes on...
TCC lockup, DFCO, closed or open loop operation, the refinements of OEM GM code plus that of hi-performance code.
On board flash memory for the calibration, takes only a few seconds up update. Data logging, playback, analysis, documentation, all included.
RBob.
Old Jun 4, 2011 | 08:34 AM
Saar's Avatar
Car: 1985 IROC-Z28
Engine: LB9
after seeing what what the megasquirt autotune did to a friend's Turbo Grand Prix, i'm kind of hesitant to want any kind of "permanent" changes dictated by software...
but the EBL is actually the cheapest of all options mentioned so far and with what seems to be the most complete options list.
Old Jun 4, 2011 | 08:54 AM
scamaro355's Avatar
Car: 92 rs
Engine: 355 stealth ram, dart heads, S480
Transmission: 4L80E
[QUOTE=Saar;4942016]after seeing what what the megasquirt autotune did to a friend's Turbo Grand Prix, i'm kind of hesitant to want any kind of "permanent" changes dictated by software...
Did your friend not have a wideband to monitor how the a/f was running? or what was the major problem with the megasquirt autotune...
The holley Dominator EFI setup looks pretty sweet....
Old Jun 4, 2011 | 09:35 AM
Saar's Avatar
Car: 1985 IROC-Z28
Engine: LB9
whatever software is intended to be used with the MS(tunerstudio?) was using the wideband signal to automatically adjust the VE tables, it decided to go WAY lean in a few spots(wideband might have been acting crazy?), combine that with boost and it killed headgaskets and sounds like it warped the heads since no HGs after that lasted a month.
Old Jun 4, 2011 | 01:17 PM
Six_Shooter's Avatar
Transmission: 5-speed/T-5
And that, boys and girls, is the reason I don't trust auto tuning EFI.
Old Jun 4, 2011 | 05:09 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
Im by no means deep into tuning (running $59 on my boosted motor)see sig for info)
but even WITH something with auto tune as "HELP" he should have been watchig that wb02 guage ,etc..
Ive been considering getting rid of the 7730 and $59 in favor of something with auto tune. For ease of letting it do most f the work and then go in and "tweek" the rest of the stuff.
Been looking at the ebl. etc. I have a Holley 950 commander on the shelf also.
F.I. 57 Belair
Aug 23, 2021 01:09 AM
customblackbird
Oct 1, 2015 04:30 PM
skinny z
Carburetors
Sep 29, 2015 11:25 PM
MitcherNeaf
Sep 24, 2015 09:23 PM
rubyred88
Sep 17, 2015 02:19 PM
