Tpi for boats
Old Sep 3, 2011 | 09:36 PM
shermanwizard's Avatar
Car: 1992 Camaro RS
Engine: 305 TBI
Tpi for boats
Has anyone worked out a way to bypass the oygen sensor on Either LB9 or L98 engines for use in ski boats?
Old Sep 3, 2011 | 10:15 PM
sailtexas186548's Avatar
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
Re: Tpi for boats
just run the O2 before the mixing elbows, shouldn't be an issue i wouldn't think doing it that way?
Old Sep 3, 2011 | 11:12 PM
Thirdgen89GTA's Avatar
Car: 1989 Trans Am GTA
Transmission: M28 T56
Re: Tpi for boats
Most boats I know of have raised exhaust that takes a downpipe so that water doesn't backflush on the engine.
At least thats the way it is on my dads 1960 Ski Natique. But thats just a carbed graymarine engine.
Old Sep 3, 2011 | 11:14 PM
Re: Tpi for boats
An L98 would make a great ski boat engine with the mid-range power. A 383 with a First intake would be more fun. Would make insane torque to run a high pitch prop.
I still think a powerglide would be a great trans for a boat. extra RPM at the prop for great onplane speed.
Old Sep 4, 2011 | 05:28 AM
Car: 1992 Camaro RS
Engine: 305 TBI
Re: Tpi for boats
The system is going on an old SB 400 to replace the worn 350 in the boat. There is really no place to install the O2 sensor.
Old Sep 4, 2011 | 09:05 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Tpi for boats
Just increase the closed loop and BLM learn enable temperature (CTS) thresholds.
RBob.
Old Sep 4, 2011 | 12:49 PM
Car: 1992 Camaro RS
Engine: 305 TBI
Re: Tpi for boats
By your suggestion it would be forcing the ECM to remain in open loop and use the associated tables for open loop.
Old Sep 4, 2011 | 01:15 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Tpi for boats
Correct, the only difference is the commanded AFR and the non-adjustment of fuel trims due to being in open loop.
RBob.
Old Sep 5, 2011 | 07:11 AM
EagleMark's Avatar
Re: Tpi for boats
I've only seen one boat with an O2 sensor and it was mounted in one cylinder exhaust. Never ran well. All inboard engines I have seen have no where to put an O2 do to enclsed cooling exhaust. All other boats run open loop. O2 sensor is an emmisions device for cars. Not needed for EFI.
Old Sep 8, 2011 | 01:39 PM
Ronny's Avatar
Re: Tpi for boats
New inboards run a cat con. I suspect they are open loop. Not sure how they protect the cat? Power is very linear. I suggest a simple task to tune.
Old Sep 8, 2011 | 06:54 PM
EagleMark's Avatar
Re: Tpi for boats
Technoligies does wonders! That's a lot more heat to take care of on an inboard? But keeping the cat cool wouldn't work? Wonder how they set them up?
I tuned a few boat conversions around here since we have about a bizillion boats and lakes. Not much off idle cruise I'll tell you that. It's all load and propeller size!
Old Sep 9, 2011 | 06:22 PM
efiguy's Avatar
Re: Tpi for boats
Isn't that just a narrow band O2 anyway? Wouldn't be very useful in a boat I would think, should be running richer than 14.0:1 most often.
Jmo.
Caspar
Jun 19, 2016 11:19 PM
theurge
Aug 21, 2015 12:46 PM
sreZ28
Aug 14, 2015 07:48 PM
Sanjay
Aug 12, 2015 03:41 PM
anesthes
Aug 8, 2015 09:37 PM
