MOTOR SWAP COMPUTER ?
Old Feb 28, 2012 | 11:40 AM
OFFROADMMD's Avatar
Car: 91 CAMARO RS
Engine: 350 TBI W HEADERS AND EXHAUST
Transmission: REBUILT 700R4
Axle/Gears: STOCK FOR NOW
I TOOK OUT THE STOCK 305.PUT N A 96 350 1TON TRK MOTOR WITH 30K ON IT.IM STILL RUNNING THE STOCK ECM.I GOT THE INJECTORS MIXED UP FROM THE 305 N 350 DURING SWAPPING.COULDNT FIGURE OUT WHAT INJECTORS TO USE..THE CAR RUNS GOOD.IM WANTING TO BUY A CHIP FOR IT AFTER I GET A 350 COMPUTER FOR TBI SHOULD I USE A TRUCK ECM OR A CAPRICE OR DOES IT MATTER ANY SUGGESTIONS.ITS GOT FULL FLOW TECH EXHAUST.AND THE CHECK ENGINE LIGHTS NOT ON..
Old Feb 28, 2012 | 11:53 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: MOTOR SWAP COMPUTER ?
you should just stick with your 1228746 ecm and you can use a anlu bcc
ftp://ftp.diy-efi.org/../pub/gmecm/b...28746%20%2061/
Old Feb 28, 2012 | 02:01 PM
Ronny's Avatar
Injectors have a # on top of them. That will tell you the inj size
Old Feb 28, 2012 | 02:10 PM
OFFROADMMD's Avatar
Car: 91 CAMARO RS
THANKS IM NEW TO THE PAGE ..IS THAT THE ECM FOR THE 305.HAVENT GOT AROUND TO GET A 350 ECM...WHERE CAN I LEARN THE ABREVEATIONS AT LOL.
Old Feb 28, 2012 | 02:14 PM
Ronny's Avatar
8746 is an ECM used in 89 - 92 F & B Cars, LO3 & LO5 Eng.
The BBC is specific for 305 or 350 and same on tranny.
Old Feb 28, 2012 | 02:26 PM
OFFROADMMD's Avatar
Car: 91 CAMARO RS
I WILL LOOK AT THAT WHEN I GET HOME.THE CAR SOMETIMES HESITATES IF YOU TAKE OFF SLOW SOMETIMES NOT ALL THE TIME.IF YOU PUT YOUR FOOT IN IT IT WILL ROAST THE TIRES.IVE REPLACED OR CHECK ALL THE SENSORS AND THE CHECK ENGINE LIGHT STAYS OFF.GOT THE CODES FROM THE CHECK ENGINE LIGHT FLASHING TO KNOW WHAT SENSORS WHERE BAD.SO NOW I WANT TO BUY A CHIP BUT I DONT WANT THE WRONG ONE IM USED TO CARB MOTORS SO I HAVE LITTLE KNOWLEDGE ON THE EFI STUFF.THE HESITATION WAS MAKING ME THINK THE INJECTORS OR COMPUTER .JEGS CHIP FOR MY CAR ONLY COMES UP FOR A 305 SO IM WONDERING WHAT KIND OF CAR OR TRUCK I NEED TO GET THE ECM OUT OF OR IF IT MATTERS.I WANT TO GET THE MOST OUT OF THE CHIP CAUSE I CAN GET THE ECM AND INJECTORS FREE.
Old Feb 28, 2012 | 02:30 PM
Ronny's Avatar
You need a 8746 ECM. only TBI 350 was a cop car caprice. search for a broadcast code for it. I dont know the ABCD or i would post. It is a common Q.
Old Feb 28, 2012 | 02:34 PM
OFFROADMMD's Avatar
Car: 91 CAMARO RS
WHERE ARE THE ABREVEATIONS AT I SEEN THEM 1 TIME NOW I CANT FIND THEM LOL I KNOW A FEW BUT NOT ENOUGH.AGAIN MY FIRST TIME ON HERE.
Old Feb 28, 2012 | 02:49 PM
utilityguy2's Avatar
First timer so you are excused for using Capitals. Caps suggest that you are hollering.
Old Feb 28, 2012 | 02:53 PM
Ronny's Avatar
ANLU5369 IS 350CID. ALL CAPS !
Available at Craig Moates downloads. It is a .binfile. You need to burn to a chip.
Old Feb 28, 2012 | 03:06 PM
OFFROADMMD's Avatar
Car: 91 CAMARO RS
note taken..no yelling lol
Old Feb 28, 2012 | 03:09 PM
OFFROADMMD's Avatar
Car: 91 CAMARO RS
should the performance be night n day after i get that chip n check those injector n ecm numbers.and another thing i was wondering is the fuel pump for a 305 n 350 tbi the same ..cause i still got the 305 stock pump in it..and would i have to upgrade the fuel pump after i get a chip
Old Feb 28, 2012 | 05:24 PM
I'm thinking it is the same.
Old Feb 29, 2012 | 06:01 AM
EagleMark's Avatar
I thought the TBI fuel pumps were the same but 5.0 and 5.7L has differant part numbers?
Definatly have to have the 5.7L injectors!
Here's a EFI dictionary and abbreviation list to get you started:
http://www.gearhead-efi.com/gm-ecm-p...ictionary.html
Old Feb 29, 2012 | 01:05 PM
I don't believe there ever was a 5.7 TBI. So there couldn't be different numbers.
TBI has fuel pressure @ 18 lbs max and TPI has @ 90 max. Pressure regulator reduces it to running pressure.
Old Feb 29, 2012 | 01:07 PM
Ronny's Avatar
350 cid for TBI was available in cop car caprice and trucks. If fact 7.4L was available in trucks as well.
Old Feb 29, 2012 | 01:11 PM
Not quite what we are talking about here but I'll grant you that you are correct in what you said.
Old Feb 29, 2012 | 01:24 PM
EagleMark's Avatar
Ah! That was why they were differant numbers! 5.0L was TBI and 5.7L was TPI that year Camaro?
Cause I know 5.0L and 5.7L TBI engines in other cars and trucks are the same.
So to answer the OP question his 5.0L TBI fuel pump will be fine in his 5.7L TBI engine swap.
Just needs correct injectors and chip.
Old Feb 29, 2012 | 01:25 PM
Ronny's Avatar
It is possible the 5.7L L05 used a diff pump. The 7.4L 1995-1996 truck used a TPI pump (34-25 lbs FP).
Edit: I see a 1991 Camaro. Eagle is correct on TPI for 2nd pump listed.
Old Feb 29, 2012 | 01:36 PM
EagleMark's Avatar
Your right there but that was an oddball. The early 7.4L TBI still used same TBI pump.
Old Feb 29, 2012 | 01:37 PM
He was answered quite a ways up the thread.
Old Feb 29, 2012 | 02:59 PM
EagleMark's Avatar
Someone had to help him out with questions after that...
Old Feb 29, 2012 | 04:20 PM
Sorry you feel that way and that earns you a report for an extremely offensive file posting.
Old Mar 1, 2012 | 09:57 AM
OFFROADMMD's Avatar
Car: 91 CAMARO RS
that number was correct thanks
Old Mar 1, 2012 | 10:12 AM
OFFROADMMD's Avatar
Car: 91 CAMARO RS
anyone have any suggetions on the chip. im thinking stage 2 .but not sure what brand to get.if it matters.
Old Mar 1, 2012 | 12:55 PM
Ronny's Avatar
If DIY does not work for you look at tbichips.com
midge54
Jan 29, 2017 07:00 PM
E Rod
Aug 28, 2015 05:17 AM
jharrison5
Aug 19, 2015 05:53 PM
355sbcTPI
Aug 19, 2015 04:38 PM
st.evel07
Aug 13, 2015 06:15 PM
