ALDL Dataloging
Old May 16, 2012 | 12:10 PM
pvr007's Avatar
Car: 88 RS Camaro,70 chevelle,92 Geo
Engine: 305 TBI
Transmission: 5 Speed Manual
ALDL Dataloging
Hi there guys... got my ALDL cable form aldlcables.com the other day... i hooked it up and i changed the baud to 4800 and the com to the correct one.. now when im running the engine i am only getting Raw data.. im using winaldl... i go for dash and it wont show anything... can someone help me out?
Old May 17, 2012 | 10:23 AM
Ronny's Avatar
Re: ALDL Dataloging
What other settings are available other than 4800? Is there a 160?
Old May 17, 2012 | 10:34 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: ALDL Dataloging
on the 1228746 don't you have to use a 10k resister to start flow ?
Old May 17, 2012 | 11:31 AM
pvr007's Avatar
Engine: 305 TBI
Re: ALDL Dataloging
I didnt put the 10k resistor... Wanted to try without if first.. Ill try with it
I tried both settings 4800 worked only
Old Nov 1, 2012 | 09:31 AM
pvr007's Avatar
Engine: 305 TBI
Re: ALDL Dataloging
Ok got it working and i have my datalog... How do i make use of it and how can i uploed it so that you guys can take a look... Thanks
Old Nov 1, 2012 | 09:44 AM
pvr007's Avatar
Engine: 305 TBI
Re: ALDL Dataloging
heres a log
File Type: txt
Old Nov 1, 2012 | 09:49 AM
Six_Shooter's Avatar
Transmission: 5-speed/T-5
Re: ALDL Dataloging
The 1227165 is the only one that "requires" the 10K resistor to start data flowing. Other ECMs can make use of the 10K resistor for other pre-programmed settings, more to verify connection, such as "ALDL idle RPM" that will usually raise the idle when there is a 10K ohm resistor present.
Old Nov 1, 2012 | 10:17 AM
Ronny's Avatar
Re: ALDL Dataloging
I used winALDL for a few years. It provided me with BLM feedback so i could make necessary changes to VE table. That helped me assure PE was in line as PE uses VE and last BLM.
What are you wishing to accomplish?
Old Nov 1, 2012 | 11:02 AM
pvr007's Avatar
Engine: 305 TBI
Re: ALDL Dataloging
I just want to get some
Data and time the car perfectly
Old Nov 1, 2012 | 12:08 PM
Engine: Lb9
Transmission: M20
Re: ALDL Dataloging
use a timing light
Old Nov 1, 2012 | 02:16 PM
Ronny's Avatar
Re: ALDL Dataloging
OUCH !
I think he is refering to set timing for optimal perf. Unfortunately that will be neded to be done on a dyno for all rpm/vac cells. If you are looking for max WOT perf for a 1/4 mile that is doable. Dataloging is helpfull to skow KC's. MPH at end of 1/4 will tell the tale.
Old Nov 1, 2012 | 06:10 PM
pvr007's Avatar
Engine: 305 TBI
Re: ALDL Dataloging
Well i also want to do prom and all that.. Would like to increase fuel efficiency
Old Nov 2, 2012 | 10:21 AM
Ronny's Avatar
Re: ALDL Dataloging
Go to TBI and read up on "free tune" in stickies. So same here on DIY-P see stickies.
Go to dynamicefi.com and at bottom is intro to tuning part 1 + 2. Good info there.
Plan on spending a few hours reading.
Old Nov 17, 2012 | 01:08 PM
88I-ROC's Avatar
Car: 1988 Camaro Iroc-Z
Axle/Gears: 3.08
Re: ALDL Dataloging
How did you got the software to work??
I just got a cable the other day, and I cant get the software to stream the data.
The laptop recognized the cable and it set it to COM3 so I changed it in the software but I'm not getting anything.....Can someone tell me if I'm missing something..?
Old Nov 17, 2012 | 08:44 PM
pvr007's Avatar
Engine: 305 TBI
Re: ALDL Dataloging
Take the 10k resister off
Old Nov 19, 2012 | 01:22 AM
88I-ROC's Avatar
Axle/Gears: 3.08
Re: ALDL Dataloging
Thanks, I actually figured it out. There is a jumper on top of the usb outlet of the cable, and I had to set it correctly in order to get true data to flow.
By the way, do you know how do I read the data. I can understand some of it, but the values of the airflow I don't know how to read it, and the EGR cycle values as well.
xodus2002
Jul 17, 2020 09:08 AM
WejaZ28
Oct 3, 2015 07:38 PM
ULTM8Z
Oct 2, 2015 01:25 PM
MitcherNeaf
Sep 24, 2015 09:23 PM
greenyone
Sep 8, 2015 08:41 PM
