Tuning Company in Penn?
Old Jun 12, 2012 | 02:44 PM
87IROCZCamro's Avatar
Car: Chevrolet Camaro IROC-Z,96 Vette
Engine: 350 5.7 Liter
Transmission: 700r
I live in IL and I need to get a tune for my car asap. It has a 383 in it and no shops around me will touch my car. The shop who built my engine said they heard of someone in Pennsylvania who tunes the computer really good and has had success with other customers with builds similiar to mine. Anyone heard of this?
Old Jun 12, 2012 | 02:51 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: Tuning Company in Penn?
Hmm, I'm not sure of anyone in PA that does these cars but have alot of EFI savy guys in the area. What system are you on? Stock electronics?
I may beable to help you out.
Old Jun 12, 2012 | 02:54 PM
Transmission: 700r
Stock Computer and everything. No MSD Ignition or anything like that.
Old Jun 12, 2012 | 03:07 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Do you have any interest in buying the chip burner and downloading tunerpro RT and learning yourself, with possible help thru emailing log files and tunes? I've done that for a few ppl with good success. IL is abit far to come out and try tuning it. It would take several iterations to get everything right.
Old Jun 12, 2012 | 03:19 PM
Transmission: 700r
I do and I dont. I have already gone through one engine blowing up (not my fault shop) and I rather have someone who knows this stuff more than me do it.
Old Jun 12, 2012 | 07:28 PM
utilityguy2's Avatar
Are you having a problem with the way the car runs? Lots of guys run a 383 on the stock chip/tune. MAF can handle overbore pretty well and the computer can learn also. If you have driveability problems then tuning makes lots of sense. Each car and engine is so very different, that's why long distance tuning is almost impossible as Orr89Rocz states.
Old Jun 15, 2012 | 11:15 AM
Transmission: 700r
Yea little bit. Car has slight hesitation and runs very rich
Old Jun 15, 2012 | 11:24 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Do you have a wideband o2 sensor on it? Plugs after cruise look dark/black?
Old Jun 15, 2012 | 05:12 PM
Transmission: 700r
No 02 Sensor, is in open loop. Plugs are black after running.
Old Jun 15, 2012 | 05:59 PM
BOSS HOGG LOU's Avatar
Car: 87 IROC Z28
Engine: 5.7 TPI
Axle/Gears: BW 9 Bolt
Next year I want to rebuild my engine and maybe add a turbo or procharger. I don't trust anyone to work on my car so I've been doing everything myself. It takes longer, but I trust ME. I've got the EBL Flash w/Port Mod Option. I am completely new to tuning and have been learning on go here. I've had a few rookie mistakes getting started but I'm running good now. The guy who makes them is very helpful. Not trying to plug a product, but I could only find one local guy who specialized in Camaro's and Corvette's. And it was an 8 week waiting list to get him to do it. You can tune your car in a weekend on your own.
Old Jun 15, 2012 | 09:29 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Kinda need an o2 to tune effectively. Either narrow band but preferably wideband. Open loop tunes generally are rich in stock settings but shouldnt be that rich at cruise with mass airflow. Unless injectors arent matching whats in the bin file
Old Jun 16, 2012 | 06:06 PM
Transmission: 700r
They are matching. The car does idle a lot and only have 50miles on engine. O2 sensor is bought and waiting to be put in.
Old Jun 20, 2012 | 06:25 AM
gw082008's Avatar
Car: 92 Firebird Convertible
Engine: 383 - First Fuel Injection TPI
Axle/Gears: 3:23
Just did a "383" in my 92 Firebird convertible.
I'm using a "FIRST TPI" fuel injection unit.
For fuel managment I went with an EBL 730 based ECM.
It is a learning experience but I feel it is worth it - to be able to "flash" in tuning parameters directly by laptop.
Dynamic EFI is located in Pennsylvania.
Good luck with your project.
Another IL "tinkerer"
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
