no signal
Old Mar 11, 2013 | 10:37 AM
kimberanton's Avatar
Car: 89 IROC-Z28 Camaro
Engine: 350 TPI IROC
no signal
i hooked a scanner up to my aldl and the scanner says to check grounds and fuses, the fuses are good, so my question is where are the grounds?
Old Mar 11, 2013 | 11:29 AM
Re: no signal
A= ground, B= 4.6v, E= 4.9v down to 1.7v flickering, F= 11.9v, M= 4.9v down to 1.7v flickering......this is my ALDL readings
Old Mar 11, 2013 | 11:53 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: no signal
The serial data Line seems low I believe it should be 2.5v or higher. The 1227165 ecm requires a 10k resister across a to b to start data flow I'm not sure what scanner you have if it does that as a automatic function. If you just the aldl a to b with the key on and are unable to put the ecm in field service mode sounds like you have a bad ecm.
Old Mar 11, 2013 | 12:05 PM
Re: no signal
its CKT 461!!! it says a 15 way IP connector in the circuit, is that behind the dash?
Old Mar 11, 2013 | 12:08 PM
Re: no signal
its says 2-5v for the series data line, i have it its just flickering, the ecm has 25 miles on it
Old Mar 11, 2013 | 01:02 PM
Re: no signal
im about to go replace the ecm, damn parts store giving me a bad part GRRRRR
Old Mar 11, 2013 | 01:11 PM
Engine: Lb9
Transmission: M20
Re: no signal
Sounds like it wasn't remanufactured correctly no big surprise there
Old Mar 11, 2013 | 05:53 PM
Re: no signal
now it wont start at all
Old Mar 12, 2013 | 09:22 AM
Re: no signal
it runs great!!! but now it wont start without spraying starter fluid in the throttle body. i think its cause of vacuum but they are all hooked up and not putting code 32 out.
Old Mar 12, 2013 | 09:26 AM
Engine: Lb9
Transmission: M20
Re: no signal
Code 32 is for the egr solonoid or temp switch. Sounds like it maybe a issue with the csi or csi timer switch.
Old Mar 12, 2013 | 12:03 PM
Re: no signal
its not popping a code anymore, my mechanic said all the data on the scanner was within specs, but i just found out my MAF is cracked inside, goin to replace it today and see how it starts
InfernalVortex
Apr 20, 2021 11:31 AM
Elephantismo
Feb 13, 2019 12:51 AM
thunder57
Nov 7, 2015 02:28 PM
TMZIrocZ350
Oct 7, 2015 12:09 PM
lewandom
Oct 1, 2015 08:15 AM
