Using ECM for ignition only
Old May 18, 2013 | 06:43 PM
maitlandtron's Avatar
Car: 1985 Z/28
Engine: L98 Carbed
Axle/Gears: 9 Bolt Posi 3.45
So right now I have a TBI system on my car.
Consists of:
L98 short block
World S/R heads, ported, 2.02/1.6 valves
Comp Cams 290H-R12
Edelbrock Torker II
Headers
3" exhaust, no cat, flowmaster 40
454 Throttle body
My plan is to install a 750 cmf carb but I would like to keep the computer controlled distributor. Has anyone done this? I'm sure i could make the TPS work on the carb if I needed it. So the only electrical components removed would be the Injectors and the IAC. Any input would be appreciated.
Old May 18, 2013 | 08:29 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
Re: Using ECM for ignition only
some ~1981-85 GM pickup trucks were that way-had a small ECM for just the distributor while the carb was a non-electronic Q-jet.these pickups had"ESC"-electronic spark control emblems and a knock sensor was used.
Old May 18, 2013 | 09:02 PM
Six_Shooter's Avatar
Transmission: 5-speed/T-5
Why?
Just used a vacuum advance dizzy, will work better than what you're trying to do with less complication.
Any reason you don't want to keep a full EFI system?
Old May 18, 2013 | 09:08 PM
Car: 1985 Z/28
Engine: L98 Carbed
Reason for not wanting to keep the tbi is simply because I feel like I'm being held back with it. The throttle body just doesn't sit right with the carb squarebore intake. I would like the keep the electronic distributor because I have access to a chip burner and I would be able to fine tune my timing curve.
Old May 18, 2013 | 09:18 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Yes, has been done, by me. See the Tuning guide book sticky on the DIY_PROM thread here. Chapter 5, under the '8746/'7747/'8063 ECM section, SA Logic.
Works a treat...
Let me see to get a link in a moment and post back.
Oh, and having ECM control over the SA is better then ECM control over AFR (only).
RBob.
Old May 18, 2013 | 09:20 PM
Car: 1985 Z/28
Engine: L98 Carbed
Awesome! I figured some had done it. Thanks.
Old May 18, 2013 | 09:22 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Here you go:
https://www.thirdgen.org/forums/diy-...cs-anyone.html
Note that this was a conversion (from carb, etc.) and I used the '747 ECM. It was the first of the TBI ECMs to be publicly hac'd. And yes, it worked a treat.
RBob,
gta892000
Aug 11, 2019 11:16 AM
customblackbird
Oct 1, 2015 04:30 PM
RedLeader289
Sep 23, 2015 06:50 AM
Johnoooooo
Sep 22, 2015 08:55 AM
Jlanz55
Sep 6, 2015 02:35 PM
