help reading my winaldl
Old Mar 11, 2014 | 11:28 PM
george88gta's Avatar
Car: 1988 Pontiac GTA
Engine: 5.7 l98
Axle/Gears: BW 9bolt with torsen carrier
20140310_150939_LOG.txt I know esc code present, never reset it after setting timing. its running rich from what I can tell. blm is low. anyway can some one look this over for me thanks
Old Mar 12, 2014 | 09:38 AM
Engine: 5.7 l98
Re: help reading my winaldl
ttt
Old Mar 12, 2014 | 02:46 PM
Ronny's Avatar
Runnin rich? Not really. BLM<128 means it is pulling fuel running at stoich. ECU is adjusting so as not to be rich. Could you benefit from a change in VE table? Possibly. Very warm weather could show BLM 115-120. Coolant temp sensor could be misreading as cold temps.
Old Mar 12, 2014 | 03:07 PM
Engine: 5.7 l98
overall does anything stand out that I am not seeing, car runs pretty good, but just want someone with more knowledge to look these tables over. if there a better way to post this table that's better to read let me know.
Old Mar 12, 2014 | 03:18 PM
Ronny's Avatar
I used winALDL year back to correct my VE tables for a mod engine.
Also handy to see my sensors read outs and any codes. Codes would show in CE light however. Not much else it does...
Old Mar 12, 2014 | 04:18 PM
Engine: 5.7 l98
i understand what it does, just looking for opinions on sensor data . does it all look in spec?
Old Mar 12, 2014 | 08:24 PM
Engine: 5.7 l98
ttt
Old Mar 14, 2014 | 07:18 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Use tunerpro rt $32b adx , It is so much easier to read. Or you can drop the data into a spreads sheet and post some of the results. It would be nice to actually see the sensors readings, tps, cts, maf, o2 swing in CL .
http://tunerpro.net
Old Mar 15, 2014 | 03:09 PM
Engine: 5.7 l98
I can't figure out tuner pro. Even after reading other posts lol. Guess Im getting old..... Geez . anyone have a simple procedure to just read data from tuner pro..
Old Mar 18, 2014 | 02:56 AM
Engine: 5.7 l98
Ttt
Old Mar 23, 2014 | 07:01 AM
armos's Avatar
I don't understand Tunerpro RT either. WinALDL data can be viewed in ALDLView.
It's taking 47 seconds to do 256 O2 crosscounts. That seems quick (good) to me.
The crosscounts also look smoother than other logs I've seen. They still have some jagginess, but I've never seen a log where they don't. It looks to me like your O2 sensor and closed loop operation are healthy.
Coolant temp is hovering around 180F, I assume you have a 180 thermostat.
I don't understand the MAT reading. It's flatlined at "8" for most of the graph, then when you shut the engine off it changes to "29". I don't know what those units are, but it looks strange. I don't want to say that there's a problem here because I'm not used to looking at the logs for a MAF car. Actually.. does a MAF car even have a MAT sensor? I'm not sure why you would, but it's showing one in the log.
I'm wondering if some of the data is corrupt.. the BLM values are a copy of the "rich/lean counter". The BPW values are huge numbers, and attempting to look at that graph crashes ALDLView. In Excel I can see the numbers for BPW and they look impossible.
I don't really see anything that looks wrong, just stuff that looks corrupt or I'm not reading it correctly.
Old Mar 23, 2014 | 07:04 AM
Engine: 5.7 l98
Thanks for taking a look. I appreciate it.
Old Mar 23, 2014 | 08:49 AM
Engine: 5.7 l98
you were viewing the win aldl file in tuner pro?
Old Mar 23, 2014 | 10:26 PM
armos's Avatar
I used a utility called ALDLView. It's described here:
http://www.fiero.nl/forum/Archives/A...-1-073532.html
That's a Fiero site but the utility doesn't seem to care what kind of car it is. The log file contains the names of what all the data values are, so that's what the utility shows. It isn't hardcoded for any particular car.
It basically just takes the data as it would appear if you loaded it in a spreadsheet, but draws it as a graph over time.
Direct link to the program:
http://www.fiero.nl/download/ALDLViewSetup0.3-2.exe
Old Mar 24, 2014 | 03:32 PM
Engine: 5.7 l98
Thanks.
Bubbajones_ya
Jul 6, 2024 08:32 PM
sahlomonic
Sep 20, 2015 07:15 PM
eustodp
Sep 20, 2015 05:09 PM
Rally Smith
Sep 14, 2015 06:59 PM
sandman92084
Sep 12, 2015 10:27 PM
