Commander 950 install Now it wont start!!
Old May 24, 2014 | 10:02 PM
seiplentz's Avatar
Car: 85 Z28
Engine: GMPP 350 HSR
Axle/Gears: 4th gen 3.42 Posi LS1
I finished my 950 install and now it won't start. So heres a quick synopsis on what I did.
Commander 950 with complete main harness
Innovate LM-2 wideband kit Added MAP sensor since I was MAF
Right now the car starts and then dies. I have tried several base maps with the same results. The car ran fine before I removed the factory ECM. Its a mostly stock 350 has a mild cam in it nothing that shouldn't stop it from running at least on a base map.
I have checked fuel pressure all ok. ECM power from OEM ecm power along with the pink/blk from under the dash for ignition. I am using a MSD 6al but it uses oe wires pink and white from the other harness.
Old May 25, 2014 | 09:22 AM
dellman83Z's Avatar
Car: 87 monte aerocoupe
Engine: 383 HSR w/ novi 2000
Transmission: Built 4l80e circle d converter
Axle/Gears: Currie 9" 3.89 gears
Re: Commander 950 install Now it wont start!!
When it does start, how long before it dies?
Old May 25, 2014 | 09:31 AM
seiplentz's Avatar
Car: 85 Z28
Turn the key cranks for a couple of secs sounds like its gonna start. Only starts for a sec or two. I can get it to start for a another second or two by playing with the fuel map but ive gone up to 50 and down to 1 in the idle area and not much of a change. I have also disconnected the distributor plug for timing and it made no difference.
Old May 25, 2014 | 01:10 PM
seiplentz's Avatar
Car: 85 Z28
Ok so after further testing today it is defiantly fuel related. I was able to get it to run a little longer by adding starting fluid. So spark is good and fuel pressure is good. I am probably missing something stupid just dont know what it is yet.
Old May 26, 2014 | 09:03 AM
dellman83Z's Avatar
Can you email a copy of the base map and a datalog. I will PM it to you. Have a feeling it may be something to do with IAC.
Old May 26, 2014 | 08:44 PM
efiguy's Avatar
I doubt it, have you checked timing during cranking? it's either that or fuel supply once the engine has fired.
And I hope you got both cheap, the Innovate and Commander 950 are slow and antiquated.
Sorry, jmo.
Old May 26, 2014 | 09:49 PM
Badass355ciz28's Avatar
Car: 1983 CHEVROLET CAMARO Z28
Engine: Forged 355 with a GT45 turbo
Transmission: TKO 600
Axle/Gears: built 4th gen rear with 3.27s
also try starting it with the map disconnected.........i had a similar problem with my megasquirt for a little while till i figured it out....now the car will run with it connected after doing some tweaking
Old May 28, 2014 | 12:31 PM
seiplentz's Avatar
Car: 85 Z28
I got it to run!!! I found the MAP KPa load scale was not set right. But I did find out if you use non Holley pro base files the data gets corrupted when opened with the pro software. So I am now rebuilding my files with the pro base maps. Not sure how I got the old ones when I downloaded them from the Holley site.
I am sure I will be back for some tuning help..
Old Oct 13, 2018 | 07:13 PM
StonersTA's Avatar
Car: 1987 Pontiac GTA
Engine: ZZ4 350 W/ HSR
Axle/Gears: 9 Bolt 3:45
seiplentz,
I know this post is from 2014 but I wanted to touch base and see if you ever got it running. I recently installed a 950 and cant keep i idling long either. Thought maybe whatever you did could help me out also.
Thanks,
Old Oct 13, 2018 | 09:04 PM
seiplentz's Avatar
Car: 85 Z28
Yes had the car running with it for a few years now.
Old Oct 13, 2018 | 09:49 PM
StonersTA's Avatar
You have any advice for a guy like myself just starting out with the 950??
Old Oct 13, 2018 | 09:53 PM
seiplentz's Avatar
Car: 85 Z28
I would need more details about your setup to try to help. I'm by far no expert but Ill try to help. The holley forums are great help and the 950 manual is excellent as well. I read that manual over and over again.
Old Oct 14, 2018 | 11:56 AM
StonersTA's Avatar
I started a new thread. If you have time here is the link : https://www.thirdgen.org/forums/dfi-...y-running.html
I list all my specs in that thread. I'd love for you to take a minute and read it and see if you can find something i'm doing wrong.
Frozer!!!
Jan 19, 2024 04:55 PM
Caspar
Jun 19, 2016 11:19 PM
justin57
Aug 20, 2015 07:05 PM
355tpipickup
Aug 19, 2015 10:02 PM
drathaar907
Aug 6, 2015 04:20 PM
