Who makes the best chip?
My car is a Monte SS but I have a 383 with the TPI SuperRam on it. Everything is basically the same as you guy have. On my Grand Nationals, we use Turbo Tweak to burn all of our chips. He's the best and the only one we really want to use. For these TPI set ups, do you guys have a go to guy? My car has a chip in it that was burned a long time ago late 90's early 2000's. I'm sure its out of date so I'm going to start looking into a new one if I can. Thanks for the info! -----Jeremy
Car: 84 El Camino
Engine: 360 TPI
Axle/Gears: 3.42 + Truetrac, Moser 28 Spline
Re: Who makes the best chip?
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Car: 89 Firebird
Engine: 355 TBI
Can a chip burner change something in the chip to turn the speed limiter off?
Car: 92 Firebird, 91 Trans Am
Engine: L31 with HSR, LB9
Transmission: 700R4, 700R4
Axle/Gears: '99 10 bolt 3.90, '01 10 bolt 3.42
Car: 92 ZR-1
Engine: LT-5
Transmission: ZF-6
Axle/Gears: SuperDana 44 4.10
Chips really are a thing of the past Jeremy. Flash based tunes are here nowadays, EBL for TPI, and SFI-6 for Grand National LC2's. If you have your heart set on a chip though, just ask Eric Marshall from Turbo Tweak to burn you one for your TPI, he should be able to do it no problem, especially if you have a history with him...
NBrehm
Aug 25, 2015 11:49 PM
