TTA NO START ISSUE!!
Car: 1987 Camaro Z28, 1989 TTA #922
Engine: lb9, 3.8L turbo
Transmission: 700r4, 2004R
Hello guys I am trying to find the culprit in a no start issue i am experiencing on a 1989 Turbo Trans AM. The vehicle was sitting for about 3 years when purchased. I have changed the alternator, starter, fuel pump, and fuel filter. The car will crank but not start up unless I spray starter fluid in the Tb. I checked the resistance on the 28 lb injectors and they all read between 11.4 and 12.4 ohms. Any input would be much appreciated, thanks.
Car: 88GTA
Engine: 5.7TPI
Re: TTA NO START ISSUE!!
Javier
You didn't mention over at TTA if you pulled your injectors out and see if they are gummed up. They could be from sitting for 3 years. Pull em and give it a shot.
It's NOT getting fuel to the intake, which tells me it fuel delivery(injectors)
What is your fuel rail pressure with KOEO?
Pull the fuel rail, it's easy enough and check. Today's gas at 3 years old will varnish in a heartbeat.
I havent checked the rail as of yet, what all is necessary to remove the injectors?
Im guessing the lines leading to the fuel pressure regulator need to be disconnected?
Car: 88GTA
Engine: 5.7TPI
Car: 88GTA
Engine: 5.7TPI
Car: 88GTA
Engine: 5.7TPI
No prob. It's pretty straight forward. Just have some rags and DON'T SMOKE while doing it. And you might as well check in at TurboTweak for a set of new injectors. Or as TTOP said, have them cleaned and tested.
I looked on their website but doesnt appear that they have 28 lb injectors?
Car: 88GTA
Engine: 5.7TPI
I just ordered the 60's with the TT Chip combo package for $324
Along with the LT1 MAF and translater, 255 lph Walbro FP, TTA Hot wire kit and Scanmaster 2.1
About 1100.
Should be good to go!
Car: 88GTA
Engine: 5.7TPI
Set of 6 42lb injectors. Works well on Turbo Buicks from stock to mid 11's safely in most cases. Part# 01D030B. Depending on what car these are used on, you would require a new chip, or ECM programming to work correctly.
Yeah you should definetely be good to go!! lol thats a nice setup! Do you take it to the 1/4? and yeah itll go on my tta just looking for something to do a direct swap and not have to mess with the current chip or ecm.
Car: 88GTA
Engine: 5.7TPI
He burns the chip for YOUR application. I just wanted to do it all and be done with it. For that price for your application, you really can't go wrong. Everything now is soooo much better than in 89 when they put this together. You would actually do the car a favor just by doing the Injector/chip combo. TOTALLY reversible if you ever wanted to.
As for the 1/4 mile with mine........no.........I pretty much drive it on the weekends and terrorize the street( like a Grandma) and then hurry back home to the garage and admire it.
Car: 88GTA
Engine: 5.7TPI
Or take them here:
Fuel Injection Specialty's
11051 Wye Street
San Antonio, TX 78217
www.fuelinjection.com
11051 Wye Street
Yup injectors are shot, does anyone know where I could get some 28lb injectors that would sit right in, since my turbo tweak chip is burned to 28lbs, or direct me towards a set that would be a direct fit. The only ones I have found for 28 lb injectors are for the ls1. Would this be a direct fit?
Eric will reburn that chip for you to a larger injector size for not too much money. You should use this opportunity to go larger with the injectors since it will give you growing room later on. Even if you do nothing and leave the car stock, the 60's will be fine. Check out the turbotweak site for a set of injectors.
If you were looking to reuse the stock injectors, send them off to an injector servicing company like Southbay fuel injection that can clean them up and make them run like new again.
Car: check
Engine: check
Transmission: check
1991-95 Supercharged
Bosch - 280-150-945
30lb Bosch fuel injectors
28.55 #/hr
FITMENT:
1991-95 Pontiac Bonneville SSEi 3.8 Supercharged
1991-95 Buick Riviera 3.8 Supercharged
RBob.
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Originally Posted by Javier87z28
Yup injectors are shot, does anyone know where I could get some 28lb injectors that would sit right in...
