Possible bad ecm i dont know
Old Aug 27, 2018 | 12:25 PM
Kyle Tice's Avatar
I just got the car about 2 weeks ago and it wont idle at normal rpm it idles at 1750-2k ive checked for vacuum leaks replaced iac and tps and adjusted both car fidnt have a cel so i decided to check the bulb it was blown i put a new one in it came on so tried to jump the aldl to pull codes and it doesnt work foes that mean its the ecm?
Old Aug 27, 2018 | 12:28 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Possible bad ecm i dont know
Sounds like a bad ecm.
Old Aug 27, 2018 | 12:30 PM
Kyle Tice's Avatar
Thats what im thinking but the car runs great other than the idle and its a 305 tpi with a 165 ecm is that what its supposed to have?
Old Aug 27, 2018 | 12:32 PM
Engine: Lb9
Transmission: M20
86-89 tpi uses the 1227165 ecm
Kyle Tice's Avatar
Also how can tell if it was the right prom
Old Aug 27, 2018 | 12:35 PM
Engine: Lb9
Transmission: M20
The memcal has 3-4 letters on it. If you post it I can identify what it’s for .
Old Aug 27, 2018 | 12:49 PM
Kyle Tice's Avatar
Old Aug 27, 2018 | 12:52 PM
Engine: Lb9
Transmission: M20
Abun is from a 87 305 automatic with 2.73 rear gears
Old Aug 27, 2018 | 12:58 PM
Kyle Tice's Avatar
Would 2.73 gears put me at 3500prm at 70?
Old Aug 27, 2018 | 01:09 PM
Engine: Lb9
Transmission: M20
Sounds like your math is off, not sure your tire height.
https://spicerparts.com/calculators/...rpm-calculator
Old Aug 27, 2018 | 07:35 PM
Kyle Tice's Avatar
Idk my gauge says above 3k and the engine is revving pretty high woukd torque converter lock up cause that is its not locking up? And what the easiest way to tell if the computer is trash
Old Aug 28, 2018 | 03:22 PM
Engine: Lb9
Transmission: M20
The higher rpm could be from the tcc not lockup up. The lack of communication from the ecm makes me think it’s faulty. The check engine light should be able to blink atleast a code 12.
Old Aug 28, 2018 | 03:54 PM
Kyle Tice's Avatar
And the ecm controls tc lock up right
Old Aug 28, 2018 | 03:59 PM
Engine: Lb9
Transmission: M20
Yes the ecm does tcc lockup on pin a7 at the ecm tan/blk.
some aldl shave the splice for the tcc on pin f. A test light could be used to see if the solenoid is getting power.
CRASHANDBURN_01
Apr 5, 2010 06:29 AM
Travis odell
Members Camaros
71
Apr 25, 2008 10:31 PM
jjlabinski
Jul 25, 2007 06:34 PM
KlayBuRn
Apr 5, 2003 04:06 AM
CrazyHawaiian
Jan 26, 2002 08:08 AM
