Bad wired EGR to ECM?
Car: Pontiac Firebird Formula
Engine: 3.1 LH0
Axle/Gears: Automatic
Hi guys, I found this thing around the EGR zone. The dark blue wire grounded to the
firewall?
Furthermore, I found this brown wire soldered to the pink/black one that goes to EGR connector. Can you tell me what kind of functions do that two wires? I just want to restore the original wiring messed up by the old owner...
It’s a 1990 Firebird, 3.1 Lh0
Thank you guys!
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Bad wired EGR to ECM?
Pink/blk is power to the ccp/ air and egr solenoid.
http://austinthirdgen.org/mkportal/m...ine_wiring.gif
Engine: Lb9
Transmission: M20
Dark blue might be the fan pressure switch. Does the fan run with the key on ?
Engine: 3.1 LH0
Thanks for your reply, the fan stays off with key on. The EGR seems always to be off too, in every condition, but I hear a clicking noise from it
Darkshot
Mar 7, 2007 09:28 PM
327_TPI_77_Maro
Oct 24, 2004 09:31 PM
Greg '85 T/A
Apr 16, 2001 06:10 PM
QUICK305
Jul 23, 2000 03:06 PM
