Tuning is there a big difference
Old Feb 17, 2019 | 07:38 PM
cpalmaccio1@gma's Avatar
Car: 90 iroc z
Engine: 358 tpi
I recently swapped motors in my 90 iroc.
I installed a 358 short block
And trick flow super 23 195 heads
Cam is a 230/234 110 lsa.
I got a safe start up chip from a good source. The cars runs idles no real issues. I was informed by the programmer that tuning is necessary and I am in the process of datalogging once my stuff arrives from moates. Here is my question
The car drives pretty dam good. Better than stock by far but I don't feel I am getting the power I should be out of it, once it is tuned using data logs will it really make a big difference in performance?
Old Feb 17, 2019 | 07:47 PM
ULTM8Z's Avatar
Re: Tuning is there a big difference
it depends on how far off your current tune is. but yeah there is potential for a big difference.
but with a set up like that, you'll definitely want a WB O2 hooked up to Tunerpro so you can catalog and see what the engine is actually doing.
Tuning blind with out a a WB is a waste of time IMO.
my guess is a safe start up chip is going to be overly rich.
Old Feb 18, 2019 | 09:26 AM
Tootie Pang's Avatar
Car: 1989 IROC Convertible
Engine: 350 TPI L98
Transmission: WC T5
Tune it.
Old Feb 18, 2019 | 09:35 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
It most certainly will as i doubt any start bin will be close enough as all engines vary some. Now how much to be gained depends how far off it is
i have had starting bins run idle ok and part throttle but be way off on wot. So it depends
Old Feb 18, 2019 | 04:40 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
You don't know if it's safe until you can see what the ecm is seeing. Could be knocking or running lean or rich. Usually these "safe" tunes mean low and sluggish spark advance and fattening up the fuel to ensure it doesn't run lean and cause damage real fast. Tuning really is necessary.
Return it, it's not 2003 anymore. Buy Rbob's programmer; the EBL. I haven't used the EBL (I'm a MegaSquirter) but I've used Moates items and was not happy with them.
Yes, it will make a difference. If you're using a shorter runner intake (because you're not running a 230/234 110 LCA cam on TPI, right?) a good starting point would be to find some spark maps from an LT4.
Old Feb 18, 2019 | 04:49 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
http://www.ultm8z.com/DIY%20Tuning.htm
Look into this
http://www.dynamicefi.com/EBL_P4_Flash.php
what tibo said
Old Feb 18, 2019 | 05:33 PM
Car: 90 iroc z
Engine: 358 tpi
Scott Hansen is tuning it to get it to run right until I learn to do it myself.
Old Feb 18, 2019 | 05:59 PM
Engine: Lb9
Transmission: M20
Speaking of knock control as tibo posted. Make sure you are using a aujp or anjf memcal. Some people convert v6 memcals to work as a v8 with cylinder select jumper. This is fine but you loose knock retard control.
Your going to be better off tuning it yourself, tons of information on $8d mask in the stickies.
Buying a wb o2 and starting with super aujp is a great way to go if you don’t want to go with the ebl. Cost wise if you buy a emulator /burner it’s not that much more for a ebl. IMO money well spent to be able to do ve learns.
You can do ve tuning yourself with spreadsheets.
https://www.thirdgen.org/forums/diy-...uide-book.html
Old Feb 18, 2019 | 08:35 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Since this isn't DIY... moved...
RBob.
Old Feb 18, 2019 | 10:04 PM
Car: 90 iroc z
Engine: 358 tpi
wow this is exactly what I needed to answer my questions on tuning. Thank you and whoever compiled and organized this is awesome
Elephantismo
May 16, 2019 08:43 AM
JDMZ28
Mar 12, 2002 10:01 PM
Hg
Feb 16, 2002 01:43 PM
Biochem
Aftermarket Product Review
Jul 10, 2001 09:20 AM
mostafa3k
Feb 19, 2001 09:57 AM
