MSD Crank trigger kit for 1992 stock HEI
Old Aug 6, 2019 | 06:06 PM
UltRoadWarrior9's Avatar
Car: 1986 IROC Z-28
Engine: 383 Gen I SBC 11:1
Transmission: Rebuilt TH700R4 for 500+HP
Axle/Gears: 4th Gen 10 bolt Eaton Truetrac 3.23
I haven't done any testing and I do realize at the very least using this crank trigger kit with any accessories would mean some effort would have to be spent in order to align the serpentine belt setup, as this crank trigger kit goes in between the harmonic balancer and crank pulley. But to my technical question...
Can the signal from this kit replace the signal from the cam on the old school 1992 HEI setup in order to make the spark more accurate by eliminating the crank to cam to distributor mechanical path?
Old Aug 7, 2019 | 07:24 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: MSD Crank trigger kit for 1992 stock HEI
Most likely yes, the pickup looks to be a reluctor type which will interface with the N & P pins of the ICM. Maybe ask Summit or MSD if it is a reluctor type of pickup.
RBob.
Old Aug 7, 2019 | 03:17 PM
Car: 1986 IROC Z-28
Thanks Bob!
I was in contact with Summit and MSD today, and MSD said it'll work with a MSD 6AL... So when the time time comes, I'd like to try to wire in the MSD ignition wheel without the MSD box first, just for S&G's. But it might be in about 1 month. If that fails, than I'll have to go with a MSD ignition control. But first I'll fire everything up stock.
BTW Bob,got in the EBL P4 Flash and loaded in the WUD to the laptop. I'm about to go plug it in to the build!
Also, got in the 1992 distributor and wires. It's not going to be long now, before first fire.
Old Aug 8, 2019 | 08:01 AM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
I'm not a huge fan of sandwiching wheels between the crank pulley and balancer.
I welded a 36 tooth wheel to the crank pulley, and I'm using a Ford pickup. Works fantastic.
I'm not really sure what the benefit is of a 4x crank trigger. ? You still need to use a dizzy to distribute spark to the correct cylinder.
If you went with a missing tooth wheel with more resolution you could run wasted spark CNP, or add a cam sensor and run full sequential spark and fuel.
-- Joe
Old Aug 8, 2019 | 09:31 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
More accurate spark timing. Eliminates a lot of monkey motion between the crank and distributor.
RBob.
Old Aug 8, 2019 | 05:16 PM
Car: 1986 IROC Z-28
So Anesthes brings up a goodpoint, it is a x4 crank signal, while the original 1992 cam reluctor wheel has 8 points. Is this a problem for the 770 ECM? Maybe this is why the MSD-6AL was recommended?
Old Aug 8, 2019 | 07:02 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Not an issue, the distributor is a 4X crank signal. Recall that it turns at cam shaft speed, which is half of crank speed (RPM). If there would have been an issue I would have stated as such.
RBob.
Old Aug 8, 2019 | 07:07 PM
Car: 1986 IROC Z-28
RBob.
Ah,sweet. Makes sense, although the cam reluctor wheel inside the distributor has 8 points. Why not just 4?
Old Aug 8, 2019 | 09:23 PM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Because the crank spins twice, the dizzy spins once.
So it's still 8 pulses per cycle, just 4 per revolution.
-- Joe
z 28 jari
Jan 27, 2015 03:02 PM
TraviZ
Sep 19, 2008 11:03 AM
rooster433
Nov 2, 2003 07:04 AM
