1992 camaro z28 computer prom
Old Jun 5, 2020 | 05:22 PM
Dave Keefer's Avatar
Car: 1986 iroc Camaro
Transmission: Manual TKX
Axle/Gears: 370
I need help with burning a chip for my 1992 L98 Camaro. I installed summit 1102 cam and now I can't get the base timing. Summit tells me I need to have my computer chip modifications for this to work. Summit doesn't have anyone. Can someone point me it the right direction. Thanks
Old Jun 5, 2020 | 09:07 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: 1992 camaro z28 computer prom
Just curious why a flat tappet cam in a roller motor ?
Old Jun 5, 2020 | 09:30 PM
Axle/Gears: 370
Well here's the problem . I have a 1995 Chevy k1500 with the L98 engine I just installed. Summit sold me the camshaft but i can't get initial timing. Summit has no one to help. Believe it or not no body works on the obd1 computer more anymore. On my 92camaro I had a chip made about 5 years ago . The company doesn't do it anymore. There's a lot of c4 better , Camaros and Firebirds around. So tell me if you want to change the stock cam what do you do ???? I would think changing the cam would be popular. Yet no one yet has an answer. That includes Summit that sold me the cam. So that's why ..
Old Jun 5, 2020 | 09:39 PM
Engine: Lb9
Transmission: M20
You might want to change your post. You make it seem like you have a 92 f body and 730 ecm.
But im guessing you have a 95 k tbi ecm. Might have to advance base timing from lo5 specs to obtain idle.
have you reached out to tbi chips for your tbi tune ?
Old Jun 6, 2020 | 06:37 AM
Axle/Gears: 370
you are correct , I do however have a 1992 z28 camaro and had pcm for less do a chip that runs my zz4 camshaft run in my L98. I am basically doing the same thing here. Same engine with a different cam. If I can find someone who does custom chips then I'm good. Pcm for less doesn't work on them anymore .I have increased my base timing and the engine seems to run fine . I'm just not certain where the total advance is and don't want to cook the engine. I have been running premium gas hoping that may help detonation . Thanks
Old Jun 6, 2020 | 07:57 AM
Engine: Lb9
Transmission: M20
Datalog and see if you get knock counts. This is diy section not really for referrals of services.
lots of information or $8d if your running a 730 ecm.
Old Jun 6, 2020 | 10:13 AM
ULTM8Z's Avatar
If you have an L98 with a factory PROM in it, and you set your base timing to the factory 6 deg, then timing at any point is what the ECM is programmed to deliver. That's of course if you're not getting any knocking, in which case the ECM will retard the timing to protect the engine.
But If you set your base timing (EST disconnected) to anything over 6, then your total timing at any point is what the ECM is programmed for, plus whatever amount over 6 you put in (unless you re-calibrate the ECM to tell it what your put in).
Here's an L98 timing map. If you put,say, 10 deg base timing, then the ECM will add 10 - 6 = 4 deg to every cell in this map.
Old Jun 24, 2020 | 08:12 PM
kenbob's Avatar
Car: 86 trans-am 1LE G92 WS.6
Engine: 305 LB9
Axle/Gears: 2.77 soon to have 3.45
Cams and speed density don't get along do the base timing also if you disconnected any smog equipment it's gonna run like a turd I have some guys here in northern Nevada that do really good tunes hit me up
FLAcamaro1
Aug 6, 2011 10:38 AM
FLAcamaro1
Jul 16, 2011 10:11 PM
AmericanIROC
Oct 15, 2010 02:25 PM
backgammon7
Aftermarket Product Review
Jul 8, 2007 01:26 PM
SubZero-Z28
Apr 15, 2003 03:55 AM
