Will memcal AAXZ work in place of AAXX?
Car: 1988 Chevrolet Camaro Iroc-z
Engine: 5.7
I have a 1988 Iroc-z, 5.7 liter, 3.27 rear, automatic transmission. I called the dealer and it shows I need an AKXX for my model camaro. All I can find is an AKXZ with tons of searches and phone calls. Just wanting to know if I can use the AKXZ in it's place. From research on this site it appears that one is for the VATS system (AKXZ) and mine without VATS (AKXX). I bought the car and changed the fuel pump and cap, rotor, plugs, wires and pickup coil. Need replacing because mice had chewed through a lot of it. Also has new ignition coil. I tried to start it but it was just put put putting, so I tried to check the codes according to my Haynes repair manual. Well when I shorted across terminals a and b in the OBD, the service engine light would just stay on and not flash or anything so I googled it. Sure enough this site pointed me to the ECM. Upon further inspection I noticed the ECM was replaced and did not have a memcal inside it, so now I'm asking for y'all's help. I'm guessing maybe the last owner brought the ECM core in and forgot the memcal inside. Thanks
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Will memcal AAXZ work in place of AAXX?
Your right akxx no vats akxz vats enabled.
if you need a memcal with akxx programmed on it send me a pm
can also use any 87 calibration or custom tuned 89 calibration.
Engine: 5.7
Thank you for a sign of hope. That is one tough part to find. I will send you a pm.
