LOG Event Reading/AE Tuning
Old Aug 23, 2021 | 01:59 PM
Cartrax's Avatar
Car: "84 Crossfire
Engine: 383 Stroker
Axle/Gears: 3.54
Enteral tune coming together and looking for some guidance on reading my LOGs. This log shows leaning on standing WOT up to 14.7 AFR, it interestingly follows the AE tip ins - some questions for the experts...
1. The leaning event - is it really simultaneous to the initial AE's or or preceding them (a LOG anomaly)?
2. Am I going too rich as it drops into the low 11's quickly?
3. Looking at AE logging, do you think more TPS AE would help alleviate that leaning?
4. Am I running too much AE i.e. getting too rich? or Does MAP-TPS mix needs tweaking? or Simply your recommendations?
Running about a.5.6, 0 to 60 and thinking I should be under 5 with my set up - at least shooting for that, thanks.
Old Aug 24, 2021 | 07:44 AM
Cartrax's Avatar
Car: "84 Crossfire
Engine: 383 Stroker
Axle/Gears: 3.54
Re: LOG Event Reading/AE Tuning
Am I asking the wrong questions here? No comments yet?
Old Aug 24, 2021 | 02:17 PM
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
You're overthinking your fueling. Look at your timing very closely. Your SA idle state is good, but it's not increasing as your RPM rises, it's decreasing. Looks as if you are running a 3500-RPM stall speed as well... at 100% TPS off idle, your timing needs to increase off of your SA idle state which appears to be around 24*, and be fully in by 3000-RPM. You're only at 19* at 3000-RPM wide open throttle, it's going the wrong way...
- Rob
Old Aug 24, 2021 | 02:42 PM
Cartrax's Avatar
Car: "84 Crossfire
Engine: 383 Stroker
Axle/Gears: 3.54
- Rob
Thanks, will look at my SA tables, do some comparisons to others and rework. Will post... Now, if you could talk Buc into sending me his I'd really have something to look at. 😁
Old Aug 24, 2021 | 02:51 PM
Are you running an EBL? Send me your Bin...
streetlethalgta@gmail.com
- Rob
Old Aug 24, 2021 | 03:15 PM
Cartrax's Avatar
Car: "84 Crossfire
Engine: 383 Stroker
Axle/Gears: 3.54
- Rob
Sent, thanks...
Old Aug 24, 2021 | 04:53 PM
Okay, I made a few adjustments that I sent you. You were running Open Loop, so I re-enabled Closed Loop. However, the BPC in your Bin looks a little off. Give me your injector size, as well as your fuel pressure, with or without any vacuum reference, I need to confirm/finalize it...
- Rob
Old Aug 24, 2021 | 05:36 PM
Cartrax's Avatar
Car: "84 Crossfire
Engine: 383 Stroker
Axle/Gears: 3.54
- Rob
Been staying out of closed loop intentionally thinking my VE's weren't there yet but OK. Running 90# injectors @ an FP of 20 w/o Vac adj. I have a VRVFPR.
Old Aug 24, 2021 | 05:46 PM
Cartrax's Avatar
Car: "84 Crossfire
Engine: 383 Stroker
Axle/Gears: 3.54
more info -Specs - 383 Stroker, Comp Ratio ~10.5:1, Speed Pro Cam 3000- Valve Lift .454 Intake & Exhaust @ .05 - Lobe Sep 110° - Duration 218° I&E, 90# Injectors, Aluminum Heads 64CC, Flow 245cc at .450 Lift. High Pressure Fuel pump, Ext Variable Vac referenced fuel pressure regulator, Renegade manifold, Long tube headers (headman), TB's are bored out to 2 inches, EBL Flash ECM, WB O2 Sensor, DUI Dizzy, MSD Ignition Module
Probably more than you wanted to know.
Old Aug 24, 2021 | 05:47 PM
Okay... based on that information you just provided the BPC is definitely off. I will take care of that for you, and I will also adjust the AE values because they will need to be changed as well. I will send you another Bin with those two areas updated in a few. Disregard the first Bin that was sent earlier because these areas need to be updated/addressed to dial in the VE properly.
- Rob
Old Aug 24, 2021 | 06:05 PM
You had adjusted the AE too much. I placed it back to the LO3 specs (55#), then multiplied by 0.61;
55/90 = 0.61
Also adjusted DFCO, Was going to adjust the Highway Mode, but I seen you disabled it so I left it alone. I just sent over a second Bin with the changes/corrections to the BPC, as well as the AE and a few other areas, Just get me a quick datalog from cold to hot so I can finalize the BLM...
Also gave you a better timing table, and quicker throttle response.
- Rob
Old Aug 24, 2021 | 06:14 PM
By the way, I also adjusted your IAC control during idle, your PE trigger points, and Launch Mode.
- Rob
Old Aug 24, 2021 | 06:15 PM
Buccaneer's Avatar
Car: 82 Corvette - CFI
Engine: 383 - Renegade, AFR 195, Bullet cam
Transmission: 700R4 - 3,200 Yank TC
Axle/Gears: 3.31
Git Er Dun!
Old Aug 24, 2021 | 06:45 PM
Cartrax's Avatar
Car: "84 Crossfire
Engine: 383 Stroker
Axle/Gears: 3.54
- Rob
Sent log. I am in awe.... Can't wait for a test run/logging.
Old Aug 24, 2021 | 06:47 PM
Okay, first datalog received. I had Closed Loop enable at 115* F, IAC steps are perfect throughout. VE is pegged Rich though, pulling a high percentage of fuel out of the VE table to Lean it out, and will send you the next Bin immediately after. Will continue doing this until I see a change in the VE, as the goal is of course stoich (128/128) at idle...
- Rob
Old Aug 24, 2021 | 06:52 PM
Alright, just sent over the next Bin. Pulled a lot of fuel out of the VE tables because your INT was down near 98, I also gave you an RPM cut of 6000-RPM so you don't over rev the engine when we get into heavy throttle. Just send over another datalog of a warm idle in Closed Loop, could be ten seconds long, that's all I need....
- Rob
Old Aug 24, 2021 | 07:05 PM
Cartrax's Avatar
Car: "84 Crossfire
Engine: 383 Stroker
Axle/Gears: 3.54
- Rob
a bit longer - duration noted...
Old Aug 24, 2021 | 07:07 PM
Okay, INT went from 98 to 110. It's getting there, Just pulled more fuel out, Bin sent.
One more datalog needed, same exact way....
- Rob
Old Aug 24, 2021 | 07:08 PM
Cartrax's Avatar
Car: "84 Crossfire
Engine: 383 Stroker
Axle/Gears: 3.54
EBL laptop does not have a wifi connection so I'm jumping around on this - reason for slow responses
Old Aug 24, 2021 | 07:14 PM
Once I see 128/128, or even 124/ 132, just as long as the average is close, take it for a spin and get on it. Datalog during the test run of course, and watch for knock as we dial in the part throttle and wide open fuel...
- Rob
Old Aug 24, 2021 | 07:18 PM
Cartrax's Avatar
Car: "84 Crossfire
Engine: 383 Stroker
Axle/Gears: 3.54
- Rob
Sent exhaust, smells leaner...
Old Aug 24, 2021 | 07:19 PM
Cartrax's Avatar
Car: "84 Crossfire
Engine: 383 Stroker
Axle/Gears: 3.54
- Rob
Sounds great! Thanks again! - pouring here now in the morning assuming weather cooperates.
Old Aug 24, 2021 | 07:23 PM
What we'll do is finalize the idle AFR tonight. I just pulled even more fuel out, as it is getting closer and closer to 120 BLM. The idle will smooth out even more once it reaches 125 BLM, and it will feel really smooth. Sent over the next Bin. Once we see 125 or 128, we'll call it a night and will wrap it up when the weather gets better so you can make some pulls. But tonight lets wrap up the idle AFR...
- Rob
Old Sep 3, 2021 | 12:28 AM
turbo z's Avatar
Car: 88 Iroc-Z Rear mount Turbo
Engine: 5.0L
- Rob
I hate to jump into this awesome thread. But I'm so excited to find someone that can help with tuning remotely 😁.
Can you help me with a tune on my 88 TPI 5.0L stock with rear mount Turbo W/EBL flash? It has an initial tune but needs some fine tuning.
Please 🙏 I'll pay for your time⁉️
-james
email:
jcanavan76@gmail.com
Phone:
425-870-2248
liquidh8
49
May 8, 2008 09:40 AM
cranknrods
Mar 4, 2008 11:14 PM
bluechevy194
Jun 11, 2006 12:25 AM
69 Ghost
Dec 7, 2005 07:06 PM
Ronny
Nov 10, 2004 08:07 PM
