1991 Firebird ECM Bypass
Old Apr 25, 2022 | 05:50 AM
OhioWorker's Avatar
After spending a year trouble-shooting my 1991 Firebird 3.1 V6 I learned the problem came from the ECM and was fixed by disconnecting the MAP sensor, EST connector, and changing the throttle manually. Now I just want to remove the ECM all together, does anyone have a guide to do this?
Old Apr 25, 2022 | 06:20 AM
aliceempire's Avatar
Transmission: T-5, TH350, T-5
Re: 1991 Firebird ECM Bypass
I'm confused. It's fuel injected and needs an ecm to run. Are you looking to convert to a carburetor?
Old Apr 25, 2022 | 06:32 AM
OhioWorker's Avatar
Yes, also I read somewhere it was hard to get to the fuel pump so I figured maybe I could put a in-line electric fuel pump and wire it to a toggle switch. I already wired the radiator fan to a toggle switch.
Old Apr 25, 2022 | 07:02 AM
There's not a lot of options to put a non computer controlled carb on a 3.1. Mid 80's s10 pickups had a non-ccc intake and carb for a 2.8. Scrounging one of those up is probably the most direct way of swapping but I don't know how easily available it would be to find. You could keep the in tank fuel pump if you used an inline pressure regulator to bring it down to 5-6psi.
Honestly it's probably easier and more parts available to fix the injection problem.
Old Apr 25, 2022 | 07:29 AM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
I hope you added a relay when you did the fan hack job. In no way can I suggest converting to carb but you will want an edelbrock 3785 and 3789 and then a regular distributor. That conversion would be significantly more annoying than fixing the fan and fuel pump properly and the loss of HP and MPG will also be a PITA.
Old Apr 25, 2022 | 10:35 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
The ECM also buffers the VSS and sends pulse streams to the cruise control and speedometer.
RBob.
Old Apr 26, 2022 | 10:09 PM
Drew's Avatar
It's considerably easier to fix the problem the right way, than it is to hack together some conglomeration of garbage. If you're not capable of fixing the problem with the original EFI, you probably aren't prepared to switch over to a carb and ever have it run as well as it would if the current EFI system was properly fixed.
Old Apr 27, 2022 | 03:44 AM
OhioWorker's Avatar
Thanks for the concern, I am in the process of switching to carb thanks to all the useful comments and so far it is going good except my speedamator doesn't work now but minor details.
Old Apr 27, 2022 | 12:57 PM
midias's Avatar
Good luck, I hope the downgrade goes well for you
Old Apr 27, 2022 | 01:13 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
the 3.1l mpfi is a good engine . Might as well fix the issue at hand cheaper more reliable decision.
Jimmy DesPro
Mar 28, 2020 07:07 PM
Oldpackrat
Jan 17, 2019 07:37 PM
Patrick Freitag
Nov 18, 2008 01:27 PM
devilfish
Apr 26, 2003 04:55 PM
