EBL Flash 2 Wide Band
Old Jul 5, 2023 | 02:14 PM
Faceman89's Avatar
Car: 1989 Corvette
Engine: 350 L98
Axle/Gears: 3.07
So I am new to tuning, just recently got myself the EBL Flash 2. Its going on a stock 89 Corvette with a SN2000 blower. Wanted opinion's on what wide band setup is preferred and who's running what. I've been eyeballing the AEM 30-0300. Description says "0-5 V and RS232 output for data-logging and feedback control"". Is this what I should be looking for? How about the Spartan setup from 14point7 ?
Old Jul 5, 2023 | 03:31 PM
aliceempire's Avatar
Transmission: T-5, TH350, T-5
Re: EBL Flash 2 Wide Band
I have limited experience in other wide band sensors so I can't really give you pros or cons by any means.
I have eblP4 and use a zeitronix zt-3. Works well so far.
Old Jul 5, 2023 | 04:51 PM
Faceman89's Avatar
Car: 1989 Corvette
Engine: 350 L98
Axle/Gears: 3.07
I will check them out thank you. And with this ZT-3, you wired it into one of the ports on the EBL ?
Old Jul 5, 2023 | 05:08 PM
yes, to one of the ABC channels
Old Jul 5, 2023 | 05:23 PM
Faceman89's Avatar
Car: 1989 Corvette
Engine: 350 L98
Axle/Gears: 3.07
Thanks for the info. I’ll most likely go with that unit.
Old Jul 5, 2023 | 05:26 PM
Faceman89's Avatar
Car: 1989 Corvette
Engine: 350 L98
Axle/Gears: 3.07
Did you have to run a splitter? Or is there a wire provided that allows you to tap into the ABC channels separate from the gauge?
Old Jul 5, 2023 | 05:33 PM
The zt-3 has it's own module and splitter to send a signal to the ebl and the gauge that came with it.
I purchased a bundle kit that includes a gauge.
Old Jul 5, 2023 | 05:36 PM
Faceman89's Avatar
Car: 1989 Corvette
Engine: 350 L98
Axle/Gears: 3.07
That’s what I needed to hear. Thanks again good sir.
Old Jul 6, 2023 | 07:00 AM
brian p's Avatar
Car: 86 IROC
Engine: Twin turbo L31 HSR
Transmission: 4L80E in progress
Axle/Gears: 9 bolt 4.11
I went with likely the same bundle as aliceempire, the ZT3 and gauge. Zeitronix seems to be one of the better brands, that's all they do. I run a EBL Flash 2 on a twin turbo small block and it works fine. If I remember correctly the Zeitronix is even in the drop down menu for WB's on the EBL..
Old Jul 6, 2023 | 09:08 AM
Faceman89's Avatar
Car: 1989 Corvette
Engine: 350 L98
Axle/Gears: 3.07
Nice. I'm going to place my order today. Thanks for the info.
Old Jul 6, 2023 | 09:42 AM
Larry's Avatar
Car: 86 Corvette
I have been using the AEM 30-0300 for several years and am pleased with it. I chose it mainly because I had limited space behind the dash where I wanted to mount it. It is permanently installed and I am still using the original sensor. The Inovate WB I had before had to be recalibrated often and I had to replace the sensor several times.
Old Jul 7, 2023 | 11:16 AM
Faceman89's Avatar
Car: 1989 Corvette
Engine: 350 L98
Axle/Gears: 3.07
I keep hearing the same bad things about Innovate.
T4Turtle
31
Oct 26, 2018 09:53 AM
lakeffect2
Jul 21, 2017 12:12 AM
soarestransam
Mar 22, 2015 08:48 AM
yellow73bb
Oct 28, 2004 01:50 PM
