Sources for 165 ECMs
Old Feb 7, 2002 | 11:26 AM
Marcos's Avatar
I've got a project 85 IROC I'm going to start working on and thought changing out the ECM would be one of the first things I would do.
When I head out to the salvage yard, what other model/year would also have the 165?
Thanks.
-M
Old Feb 7, 2002 | 07:21 PM
TC602's Avatar
Car: 86 IROC
Engine: ZZ4
Transmission: T5 WC
Go here http://www.cruzers.com/~ludis/p4xref.html and check it out. There are many cars that used the 7165 ECM. You might get one cheaper if it's from a different car. Camaro name could = more money. This site list all the different ECMs used in different model GM cars.
Tom
Old Feb 10, 2002 | 12:56 PM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
Late 80s 4 Cylinder TBI Trucks are a major cheap source of 165s.
Old Feb 19, 2002 | 05:31 PM
85wilrocu's Avatar
Hey man do you still have the maf burnoff module, for the 85 iroc?
If you don't know what it is, it's piggybacked on the ecm!
Thanks,
jpaisano@telesiscu.org
Old Feb 19, 2002 | 05:45 PM
Marcos's Avatar
yeah, I still have it. Infact, all of the 85 stuff is still in there. I won't be swapping it out for a while unless it's fried. I take it you're interested in the burnoff mod? Unless you need one right now, I'll let you know what happens with mine.
Old Feb 19, 2002 | 05:59 PM
85wilrocu's Avatar
Yeah man i need one like asap!
Are you willing to sell?
Old Feb 19, 2002 | 08:54 PM
Marcos's Avatar
sorry man, like I said, I'm not planning on doing the swap in the near future. May be a couple of months before I get around to it.
Old Feb 20, 2002 | 11:45 PM
james_85Z28's Avatar
Car: 2003 Porsche C4S
Engine: 3.6L
Transmission: 6-speed Manual
I have a bunoff module available. I'm located in westminster by the I-405 and the 22 fwy. I swapped to the 165 ECM about a year ago.
e-mail me if your interested.
How do you know if it's bad?
jfearn@socal.rr.com
Old Feb 21, 2002 | 06:39 AM
RosiRonja's Avatar
@james_85Z28
Did you have any problems during the switch to 165?
What are the changes?
Rosi
Old Feb 21, 2002 | 08:02 AM
Marcos's Avatar
Here are a couple of good links on this swap:
http://www.geocities.com/transam85tp...p_Pictures.htm
and
www.eecis.udel.edu/~davis/z28/ecm_swap/.
I know I'm going to do this swap sometime this summer, but I sure wouldn't mind hearing about peoples experiences with doing this swap. Is there a better resource out there for how to do this?
Old Feb 21, 2002 | 07:09 PM
Engine: 3.6L
The swap took about 4 hours. It's pretty easy as long as you have the two new relays, pigtails for relays, and a diagram of which wires are changing to what. I did it right the first time and it started right up and I haven't had a problem yet. Just be careful to verify the wiring changes and not to explicitley trust any site for absolutely correct pin changes.
Old Feb 21, 2002 | 07:24 PM
Engine: 3.6L
Mike Davis's site is where I got the inspiration and the knowlege to do it. Just confirm the pin changes and be aware that some of the diagrams are from a corvette and the wiring is slightly diferent from the camaro wiring.
Basically you swap several pins on the wiring plugs and you create the circuit shown below. I used a memcal from an 89 camaro and disables the VATS with my burner. My engine was stock at the time of the swap. I wanted to get experience burning PROMS while my engine was stock and old, rather than learn on an engine that required perameter changes to run OK.
Old Feb 21, 2002 | 10:40 PM
RosiRonja's Avatar
Many thanks for your advice.
Will I need any specialty relais?
Or will others(a´ve several from crashed cars) do the job.
For what I´ll need them? Maybe I can look over my shelf to find them.
There is only the last problem: where to get the 1227165?
We will find one.
Many thanks again and best wishes.
Rosi / germany
Old Feb 21, 2002 | 11:08 PM
Engine: 3.6L
165 ECMs are probably hard to find in Germany. They were installed in 86-89 V8 TPI camaros and corvettes. They are somewhat rare to find in my local junkyards. I got mine from e-bay.
Old Feb 22, 2002 | 09:35 AM
RosiRonja's Avatar
Or will others(a´ve several from crashed cars) do the job?
Rosi / germany
Old Mar 1, 2002 | 10:20 AM
Car: Death Mobile
Engine: 666 c.i.
Didn't anyone read my post above about getting them out of late 80s 4 cyl TBI small Chev S10/GMC trucks?
Old Mar 1, 2002 | 01:09 PM
RosiRonja's Avatar
Glenn91L98GTA
yes I read your post on that.
But what I mean was a phone# or e-mail adress
because we do not have a lot ´80 small P/U´s in the scrapyards here in germany.
Have a nice day
Rosi
1Aauto
Sponsored Vendors
Jan 20, 2016 01:01 PM
1Aauto
Sponsored Vendors
Dec 2, 2015 03:53 PM
thunder57
Nov 7, 2015 02:28 PM
2012sergen11
Oct 13, 2015 07:38 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
