How do you LINK to Craig Moates???
Old Apr 17, 2002 | 03:19 PM
craiger's Avatar
I recrntly purchased an ibm think pad (233) and a cable from Steve Ruse. I have the cable installed correct, black to black & red to orange...pins a &M. Why can't I link up? I am running win ME and when I click on the folder, then click on startrun, the program operates fine off line. in diagnostics, i get the intro, then one line stating sending request: f4-57-1-0-B4 , then it states; Receiving Echo/responce:F4, 57, 1, 2, B4 . And that is it! I press 1 durring this time and nothing? I have done this and put a 10k ohm across pins a and b with the same results.
I am working off of Com 2 because my Thinkpad has com 1 reserved for the printer. I have removed my IR port because read that it can cause conflicts. I set CM software to com 2, 730 ecm, and have no idea what i am doing wrong? I am running ME, but it seems to run fine when i click on the startrun in the ecm850 folder i put in my documents.
Can anyone help?
Old Apr 18, 2002 | 05:48 PM
Craig Moates's Avatar
Car: 87 T/A
Engine: 441 SBC 12.5:1 0.680" Lift
Axle/Gears: 4.10 TruTrac Moser 9"
Yes, it appears to run fine in WinME. However, the program needs to access the COM ports without layers of Microsoft Bloat. It cannot do that with WinME up and running. Boot up in DOS mode and it should work fine.
You'll also probably want to supply power to your adapter like we discussed, but first just try a DOS or Win98 boot disk. It's so easy, and could save you hours of sitting around asking yourself why it doesn't work.
Old Aug 29, 2003 | 02:47 PM
lostangel's Avatar
Car: 86 Z28
Engine: 305TPI stock
Transmission: TH700R stock
i've seen this mentioned a few times. how do i supply power to my adapter i'm in the same boat.
Old Aug 29, 2003 | 05:01 PM
Denis.V's Avatar
Car: 1986 Pontiac Firebird Trans Am
Engine: 305 Tuned Port Injection
Transmission: The famous 700R4
Axle/Gears: No idea
Power: EASY!.
I installed a 9 volt battery + a small swicth in the circuit (replacing the common 12 v connector to cigarr. lighter). When I ready with my laptop, I put the switch in ON and ... a lot of data is available....
Regards,
Denis V.
Old Sep 5, 2003 | 10:22 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
mine is one of steves as well, I get the same "sending request: F4-57-1-0-B4" but the echo response says nothing.
I also dont know why my cable has a red a black and a white or grey colored wire. What the heck would that one be for? The moates software sez "try a 10K resistor between A and B" I did and no change. any ideas?
Old Sep 5, 2003 | 10:32 PM
SATURN5's Avatar
Car: 84 SVO
Engine: Volvo headed 2.3T
Transmission: WCT5
Axle/Gears: 8.8" 3.73
Tom,
most cables require three connections to the car. 12v power, ground to aldl connector (connects to ECM) and aldl data.
Also the 10K is for MAF (165) ECMs to force aldl data output. The 730 with SD aldl data is software commanded.
BW
Old Sep 5, 2003 | 10:41 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
so 12v to that wire and Im golden?
Old Sep 5, 2003 | 11:06 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
well 12V to the "other wire, hooked up black and red wires still nothing, tis is so frustrating.
program set to com 1, serial set to com 1
I bet guys with FAST or gen 7 dont have to go through this stuff
Old Sep 6, 2003 | 11:08 AM
lostangel's Avatar
Car: 86 Z28
Just to make sure i got this right. Black is ground through terminal A. Red is Data through terminal E or M. White is supposed to go to terminal B but I don't know what it does. Is the 10 K resistor still required with Steve's cable? Does Steve's cable require the 12v if so where does that tie in?
Old Sep 6, 2003 | 12:39 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
is B 12 volts? is good for the supply of 12 volts? I still have no connection and I am gettiing frustrated.
Fanatic1074
Oct 3, 2022 05:57 AM
3rd gen money
Oct 11, 2019 09:57 PM
Ed1LE
Sep 30, 2018 09:14 AM
loud91rs
Oct 5, 2015 10:05 PM
SavingPvtEric
Sep 29, 2015 05:59 PM
