LT1 VE tables
Old May 21, 2002 | 02:00 PM
jnjspdshop's Avatar
LT1 VE tables
Does anyone know where I can find examples of LT1 VE tables. I am not looking for a .bin file, maybe some who has a table with the number so I can get an idea on where to start with a Miniram L98 motor. I already have the EGR disabled, and the injector constant set correctly.
Old May 21, 2002 | 08:12 PM
camaroguy99's Avatar
Someone correct me if I'm wrong, but I am pretty sure that the LT1 is a MAF system. If the LT1's use a similar VE table to the 730 ECM's then you aren't going to be able to translate it to a MAF car (pre 1990). The MAF's use a 2D grams per second v. RPM to obtain the correct amount of fuel. If it's a MAP (Speed Density, 90-92) ECM then you are still going to have problems because the LT1's tables will be in terms of g/sec not the MAP v. RPM v. VE that you need for the SD system.
Either way I would look for someone else that has a miniram from your style car and go from there.
Old May 21, 2002 | 10:34 PM
jnjspdshop's Avatar
I am pretty sure either a 93 or 94 LT1 engine has VE tables because it is speed density and not MAF
Old May 22, 2002 | 02:05 AM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
92 & 93 are SD. 94-up is MAF
Old May 22, 2002 | 08:04 PM
Alright, I was under the impression that all LT1's were MAF systems. I stand corrected.
Old May 22, 2002 | 11:26 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
I can't speak for all the LT1s, but the 95s have both sensors.
The PCM uses the MAF primarily and then the MAP to independently double check the MAFs calculations. If you disconnect the MAF then it will run on the MAP. there is a switch setting to set the PCM to a MAP Only Mode.
Old May 25, 2002 | 02:50 PM
Wilson's Avatar
Just a note 93' Fbody's are all SD as for 94+ Fbodys are all MAF. However, if you look into the PCM of the 94+ Fbody's they have the tables for VE vs RPM vs Load but it has been debated if it is even used over at the LT1Edit list (94+ Fbody editor list). It is now believed that the only time that 94+ Fbody's use the VE tables is when it is run in SD mode.
Old Jun 5, 2002 | 08:11 AM
89vette's Avatar
I have some SD LT1 bins to look at if you like. They are not like MR VE tables for some reason.
Jason
Old Jun 5, 2002 | 10:10 AM
JPrevost's Avatar
Car: 91 Red Sled
http://www.malcams.com/legacy/New/LT1/Stock_VE.htm
Old Jun 5, 2002 | 03:47 PM
GofasterFirebird's Avatar
Car: 1991 Firebird
Engine: 427 LSX
Transmission: Turbo 400
why wouldn't they be like the MR tables?? could you send me them?
Old Jun 5, 2002 | 08:03 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
So you've seen into the 96 MY stuff?.
I do believe the OBDII requirements are that two independent procedures be use for diagnostics. That was a 96+ item.
Yes, you can 0 the MAP stuff out and have the car just fine on the 95- cars. Or run a 95 in MAP only.
antman89iroc
36
Jan 31, 2016 08:42 AM
88SS6SPEED
Nov 11, 2015 07:05 AM
L0tuS
Oct 4, 2015 08:07 AM
WejaZ28
Oct 3, 2015 07:38 PM
ULTM8Z
Sep 16, 2015 09:15 AM
