Newbie, just starting to tune
Old Jun 8, 2002 | 01:11 AM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
Engine: 350, ZZ4 equivalent
Transmission: Pro-Built Road Race 700R4
Axle/Gears: 3.23 Dana 44
All right I have been burning chips for like a mouth now I am using the ARAP bin. I was knocking a lot so I decided to tone down the timing. I would like to know if I am doing this the right way and most efficient way. I first went for a drive and recorded a few hard accelerations in my car using Craig Moates software. Then I loaded the data in excel and I looked at the RPM and Load that I was getting knocks and timing retard at and lowed the timing in TunerCAT there. Is that the most efficient way of tuning your timing tables just by messing with it a little bit then going out and recording data and doing the same thing over again? Does anyone have any tips?
Here is a copy of my 3 hard accelerations, the first run the car is in open loop
File Type: zip
Old Jun 9, 2002 | 01:35 PM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
ttt
Old Jun 10, 2002 | 12:18 PM
tpi_roc's Avatar
Sounds good to me
By the way if you're getting knock showing up at a certain RPM I'd make your changes a few hundred RPMs before that instead of RIGHT at the number
Old Jun 10, 2002 | 01:09 PM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
Should i keep, lowering the ARAP timing advance untill i get no knock at WOT. Is that what you do, or do you have some knock at WOT?
Old Jun 10, 2002 | 02:36 PM
tpi_roc's Avatar
Its acceptable to have minimal knock counts, If its under WOT just try to keep the amount of timing it retards to a minimum.
Old Jun 10, 2002 | 03:51 PM
AlexJH's Avatar
Engine: 5.7L V8
Are you doing this in the 3D spark table, or in the PE Spark Advance array? Not sure what it's called in TunerCat, I use WinBin.
Old Jun 10, 2002 | 04:59 PM
tpi_roc's Avatar
89 Iroc Z
What version of craigs software are you using? The output is alot cleaner than mine. Do you have something parsing the file or is that the way it dumped?
Old Jun 10, 2002 | 06:53 PM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
I am using version 8.51. His software dumps it into a .csv file. I then went through it and made it a lot cleaner and highlighted the engine knock areas.
Old Jun 11, 2002 | 12:16 PM
tpi_roc's Avatar
I was a few versions off, it was the title font of the columns and the highlighting that threw me off, I thought maybe that was the way another scanner dumped.
Old Jun 12, 2002 | 12:35 AM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
I am pretty sure there is a way to make excel automaticly do this so you don't have to go through it and clean it up. I'll look into it.
Old Jun 12, 2002 | 01:18 AM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
I am making a Macro to do this.
Azrael91966669
25
Jun 20, 2017 04:04 AM
Orr89RocZ
Apr 25, 2016 08:28 AM
R3500
Aug 24, 2015 09:05 AM
ezobens
Aug 19, 2015 10:29 PM
mizz0313
Aug 12, 2015 06:45 AM
