With Ford 30lbs injectors..........???
Old Jun 13, 2002 | 12:11 PM
86Tra/maro's Avatar
From: Newark,NJ The state where racing on I 78 rules.
Hello everyone,
I have a question burning a chip with my 30lbs Ford injectors. Do U change the Ford 30lbs injectors in the injector values to maybe 32-34lbs injectors?
Old Jun 13, 2002 | 12:46 PM
tpi_roc's Avatar
about 2lb/hr over what ford rates the injector at.
Old Jun 13, 2002 | 08:21 PM
Guest
Guest
Posts: n/a
It depends on what fuel pressure you are running. I have mine set at 34.
Old Jun 14, 2002 | 04:14 PM
MikeH's Avatar
Car: 90 IROC
Engine: 406
Transmission: GMPP 93/4L60
Axle/Gears: 9 bolt 3.27
IM running 48lbs of FP and have mine set for 35 lbs in the chip. This gave me the most 128s to start with, just have to see what works best for your setup.
Old Jun 14, 2002 | 06:03 PM
ryn28's Avatar
Car: 1986 Camaro Z-28
Engine: Chevy ZZ4
Transmission: Select Built 700R4
Axle/Gears: Moser Axles / 3.73 Richmond Gears
I was wondering about something similar b/c I recently installed 24# SVOs. After the install I lowered my fuel pressure to about 40lbs. figuring to start with a low pressure and go from there. After a few brief tests to get my blms close to 128 I had to program my prom as if I had 22#'s. So far this seems to have gotten me pretty close and I know I should give the car what it wants, but does this seem strange at all? So far I haven't heard anyone using these 24# injectors and setting them to a smaller size. Right now I'm using an ARAP with a stock 89 350 timing table and few other minor changes.
Old Jun 14, 2002 | 06:10 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
When changing injectors.
You set the F/P to get the cruise, light throttle stuff close.
The correct the idle BLs with the battery voltage table.
Different injectors function differently at different voltages, so the intial biasing may be wrong. The different characteristics of the opening and closing times of the injectors is taken care of in the volatge table.
Once you get the idle and cruise right then you can start dialing in the WOT stuff.
Old Jun 17, 2002 | 05:13 PM
ryn28's Avatar
Engine: Chevy ZZ4
I'm wondering then, should I raise the fuel pressure to around stock GM 43psi, set the injector constant to approx. 26# and then mess with the PW correction or is the way I have it just fine? The blm's are between 126-128 at cruise the way I have it now. I haven't messed with WOT at all since I'm not there yet. It's still strange to me that I seem to be the only one running SVO 24#'s at a lower injector constant. Could my voltage be that different from everyone elses that I'm forced to run the inj. constant so low?
I don't want to start tuning other aspects if my initial settings are wrong to begin with. That's really the reason why it's bothering me so much.
Old Jun 17, 2002 | 05:27 PM
kvu's Avatar
kvu
My 30lb accels are set at 35.5 constant @43-47max psi.
Old Jun 18, 2002 | 05:04 PM
ryn28's Avatar
Engine: Chevy ZZ4
Nevermind that babble above. Sorry for that. I have afew things I'm going to try. I wasn't thinking totally straight when I posted that last one. Gotta keep reading the archives and doing more searches. I get just a little closer to a better understanding of this each time I do. Thanks for your help so far guys.
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
mcbitchman
Sep 30, 2015 01:00 PM
mcbitchman
Sep 29, 2015 12:32 AM
82xCAMAROxZ28
Sep 27, 2015 12:31 AM
