Headers Glow red.......>>>>....ouch!!!
Old Jun 14, 2002 | 07:07 PM
86Tra/maro's Avatar
From: Newark,NJ The state where racing on I 78 rules.
My headers glow a dull red when I leave the the throttle cracked open at about 1500rpm in neutral. I have the Ford 30# injectors set up in the BIN file for 32#. Could this be the problem?? My combo is in my signature.
What tables modify the part throttle air/fuel ratio?
Old Jun 14, 2002 | 08:12 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Messin with the MAF has fubar'd it's calibration.
With that being like that, it's anybody's guess where your at.
try tuning it for normal situations first.
High idle in neutral is not really a Normal Mode of operation.
Old Jun 15, 2002 | 12:04 AM
goneracin's Avatar
Usually glowing headers comes from unburnt fuel burning in the pipes. This is normally a sign of not enough timing, although a way off fuel curve can do this also. What does the scanner say?? Blm's should show way off. Real radical pump gas motors will do this on the dyno at lower rpm's (pretty cool to watch) even when they are tuned pretty well, as the efficiency at lower rpm isnt good enough to burn all the fuel.
Old Jun 15, 2002 | 04:33 AM
JPrevost's Avatar
Car: 91 Red Sled
Does it look like this?
Old Jun 15, 2002 | 08:13 AM
goneracin's Avatar
JPrevost, thats a pretty wild picture. We had a whipplecharged pumpgas boat motor on the dyno would do that also. Everyone in the building had to go see it with the lights off. BTW, what induction is on that:??? Loks like some kind of IR EFI?
Old Jun 15, 2002 | 05:57 PM
86Tra/maro's Avatar
Grumpy,
Is there a way to measure what the actual maf#s are?
gta892000
Aug 11, 2019 11:16 AM
Rousseau92maro
Feb 1, 2016 05:12 PM
redformula88
Oct 14, 2015 06:08 PM
AmpleUnicorn88
Sep 24, 2015 09:15 AM
andy74
Sep 3, 2015 08:41 AM
