Any of the pros seen this?
Old Jun 17, 2002 | 01:40 PM
tpi_roc's Avatar
With all theorys and wives tales aside...
Have any of you established pro's (you know who you are ) seen solid lifter (whether flat tappet or roller) be a source of knock counts?
And purely out of curriosity, how about pete jackson noisy gears?
Old Jun 17, 2002 | 02:35 PM
TRAXION's Avatar
Car: 2005 Subaru STI
Engine: 153ci of Turbo Power!
Transmission: 6-Speed
And this is related to what DIY PROM issue that you are working on?
Tim
Old Jun 17, 2002 | 02:53 PM
tpi_roc's Avatar
Yes mistar tim
The time i spent ridding the ARAP of knock I dont want to go to solid lifters and pick up knock counts again
Old Jun 17, 2002 | 04:59 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Re: Any of the pros seen this?
Originally posted by tpi_roc
Have any of you seen solid lifter (whether flat tappet or roller) be a source of knock counts?
Yes, and no.
I've had a solid cam play hell with the K/S, and yet my noisy roller lifter setup doesn't.
With the newer ramps the cam guys are using, there really isn't any advantage to the solids. You can make a solid lifter lighter then a hydralic, thou.
It's all about frequencies, and amplitude.
Old Jun 17, 2002 | 05:17 PM
tpi_roc's Avatar
Appreciate the response grumpy..
There comes a point in modding where you run out of things and need the next step, although not there yet I'm leaning very heavily towards a solid roller cam in the 385, but I dont want to shoot myself in the foot with false knock. I'd like the advantage of being able to rev it the way the LT1 intake wants and not being to concerned with float, also the heavier ramps are mighty appealing however 'advanced' the hydraulic rollers may be now.
Is your solid setup roller or flat?
Does decreasing lash at all help? Or are you kinda stuck with what the G0Ds give you?
Old Jun 17, 2002 | 05:25 PM
kvu's Avatar
kvu
I have the same problem,my 400 is externally balanced,and gets false knocks so bad I turned it off.
Old Jun 17, 2002 | 05:43 PM
tpi_roc's Avatar
All 400's unless remachined (usually aftermarket cranks) are externally balanced. What is it that caused your false knock? Simply you didn't have a K/S tuned for a 400? Out of balance? or is it solid?
Old Jun 18, 2002 | 10:16 AM
kvu's Avatar
kvu
It 's just engine harmonics of a 400 I guess.
tmellott89
Oct 14, 2015 02:06 PM
Pinguiclia
Oct 12, 2015 04:47 PM
djmarch
Oct 2, 2015 10:41 PM
MitcherNeaf
Sep 24, 2015 09:23 PM
jbates346
Sep 22, 2015 05:22 AM
